cubanflyer
Full Member level 5
oh i see.. and by the way im using a hobby servo for this.. i should be able to get this now. how about the speed? how will i control it? thanks!!!
The speed of the servo depends on the model. the are usually quoted as 0.22 sec/60 degree at 4.8v, this is the rating for a futaba S3152. If you wish to control the speed from 1 position to the next, rather than just entering the end position and allowing the servo to operate at its normal speed, you will need to move the arm by slowly increasing the pulse width until it is in the required position.
