montolivo
Newbie level 1
- Joined
- Mar 12, 2008
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,283
panasonic nv ds30 instructions
oh good this forum
oh good this forum
will try that thanksdufinc said:I have solved the blinking LED problem, the 2 or 3 blinks every 2.5 second means that there is a Reel lock situation. ,-- but it is a "false" message.
The real problem is the T and S reel detector cable (FPC flatcable), probably because of so called Fretting, the signal cable looses contact to the FPC connector.
To solve this Bl.... annoying problem, remove carefully the bottom cover on your NV-DS60, carefully rock the cable 1 mm in and out of the connector a few times, ----- voila the problem disappears. I have attached two pictures, one showing the T(arget) and S(ource) reels, and another pointing out the connector location.
Lars Hansen, 06-2006
shanda said:Hi,
I have a Panasonic NV-DS30 and the power light flashes. I can see images on the display but can not record. I can not even play the tapes. Any idea what wrong. I have the original manual but there nothing about flashing power light.
Unfortunately I have ascertained that the version of MotionDVStudio suitable to the operation with the door firewire is the 3.0 while in the link that I have posted there is the 6.0.what it works only with door USB.... The continuous search.I answer to myself: the program Motion DV Studio contained in the cd VW-DTM20E can be found it to this :arrow: address:
:wink:
