[SOLVED] Serial communication using USART
Here's the code
// Program to receive data from USART and displaying it on LCD
Receive data from serial port and display it on LCD
LCD DATA port----PORT A
ctrl port------PORT B
rs-------PB0
rw-------PB1
en-------PB2
using external clock frequency 12MHz
#define F_CPU 12000000UL
#define USART_BAUDRATE 9600 // Baud Rate value
#define BAUD_PRESCALE (((F_CPU / (USART_BAUDRATE * 16UL))) - 1)
#include<avr/io.h>
#include<util/delay.h>
#define LCD_DATA PORTA //LCD data port
#define ctrl PORTC
#define en PC2 // enable signal
#define rw PC1 // read/write signal
#define rs PC0 // register select signal
void LCD_cmd(unsigned char cmd);
void init_LCD(void);
void LCD_write(unsigned char data);
void LCD_clear();
void usart_init();
void usart_putch(unsigned char send);
unsigned int usart_getch();
int main()
unsigned char value;
DDRA=0xff; // LCD_DATA port as output port
DDRC=0x07;
_delay_ms(100); // signal as out put
init_LCD(); //initialization of LCD
_delay_ms(50); // delay of 50 milli seconds
usart_init(); // initialization of USART
LCD_cmd(0xC0); // to go in second line and zeroth position on LCD
while(1)
value=usart_getch(); // Call a function to get data from serial port
LCD_write(value); // write data to LCD
return 0;
void init_LCD(void)
LCD_cmd(0x38); // initialization of 16X2 LCD in 8bit mode
_delay_ms(50);
LCD_cmd(0x01); // clear LCD
_delay_ms(50);
LCD_cmd(0x0E); // cursor ON
_delay_ms(50);
LCD_cmd(0x80); // ---8 go to first line and --0 is for 0th position
_delay_ms(50);
return;
LCD_DATA=cmd;
ctrl =(0<<rs)|(0<<rw)|(1<<en);
_delay_ms(50);
ctrl =(0<<rs)|(0<<rw)|(0<<en);
_delay_ms(50);
return;
LCD_DATA= data;
ctrl = (1<<rs)|(0<<rw)|(1<<en);
_delay_ms(1);
ctrl = (1<<rs)|(0<<rw)|(0<<en);
_delay_ms(1);
return ;
void usart_init()
UCSRB |= (1 << RXEN) | (1 << TXEN); // Turn on the transmission and reception circuitry
UCSRC |= (1 << URSEL) | (1<<USBS) | (1 << UCSZ0) | (1 << UCSZ1);
// Use 8-bit character sizes
UBRRL = BAUD_PRESCALE;
// Load lower 8-bits of the baud rate value into the low byte of the UBRR register
UBRRH = (BAUD_PRESCALE >> 8); // Load upper 8-bits of the baud rate value..
// into the high byte of the UBRR register
while ((UCSRA & (1 << RXC)) == 0);
// Do nothing until data has been received and is ready to be read from UDR
return(UDR); // return the byte
Every thing is working perfectly. The cursor goes to the next line and moves right for every character that I type. The only problem is that some kind of symbol is displayed instead of alphabets.
Is this for every character you type or just intermittently?
BigDog
why are you bringing other topics into this thread, and moreover you also started a new thread for the same topic... i would delete all the threads posted by you as , there seems to be no point in this thread, its simply going on and on and on, for a simple serial communication, i dont think 50 posts are required....
i would delete all the things related to rfid as you already started this thread seperately....
