unavezmasysale
I need to sense a differential voltage of 2000mV and the source is very noisy.
I think to use a Intrumentation amplifier, but I have two limits. The first is the supply voltage, I have 12V or less and 0V, not negative voltage. And the second one, is that I need to read this voltage with a DSP(3.3V).
I though to add a 1.65V offset voltage, so I will be in the middle of the voltage range.
Which could be a good solution for this problem?
Thanks.
Thanks.
