yokohama
Member level 3
I'm not sure that I've well understand this section can you please be more precise or can you suggest a diagram ou schematic ? Thank's. Because I think It's very important.When I had to do something like this, I put my 0.1 Ohm current sense resistor directly in the solenoid connection. That means the voltage signal from the current sense resistor is now differential, instead of single ended and ground referenced. Therefore I had to use a somewhat exotic opamp circuit with very good CMRR and common mode range that included the supply rail. Not easy, but not too hard either. And it does give me the true current through the solenoid all the time - both when the FET is on and when it is off.
