- Joined
- Jan 22, 2008
- Messages
- 53,703
- Helped
- 14,811
- Reputation
- 29,919
- Reaction score
- 14,440
- Trophy points
- 1,393
- Location
- Bochum, Germany
- Activity points
- 303,612
You can connect whatever you want, but I don't think it's useful.or if DC Motor is used with 15V reverse connected battery can I get continuous mode of operation ?
As said, you need an "active load" (a load sourcing power to the SCR bridge) to achieve 4th quadrant operation. The lab setup is driving the load motor by a second DC motor to put it in generator mode. A negative voltage source can model an active load, but what's the purpose of using the voltage source together with a motor?
10k is about "no load", don't know what it's good for. I don't feel responsible to fix an unsuitable test setup, however.In Proteus 50mH and 12 Ohms is used. In real hardware 50mH and 10k is used.
