SAR using PSoC 5LP
wwfeldman
I am using VDAC8 and ADC_SAR to convert analog to digital and back, in KIT059, PSoC5LP.
A for loop assigns the digital value to the DtoA, whose output is buffered by an op amp follower.
The output is fed back into another buffering opamp and then to an A to D converter, ADC_SAR.
the program:
#include "project.h"
#include "stdio.h"
#include "string.h"
#include "math.h"
uint8    i, ii, j, jj, k, kk;             //index variables
uint8    temp = 0, startflag = 0;         //0 = wait 1 = start
//declare linear regression varibles
uint8    n = 0;
double   x, y = 0;
double   xsum, ysum = 0;
double   xy, xysum = 0;
double   x2, x2sum = 0;
double   num, den, slope, intercept;
double   zero = 0;
double   kkk;
char8 res[16u];
double   value, fracpart, intpart ;    //value is real, frac is fractional part, decim is whole number part
uint8    intfrac, intdecim, decim, frac;
// function:
void lma_clear_display(void)
    //clear dispaly
    for(j = 0; j<=3; j++)
        LCD_Position(j,0);
        LCD_PrintString("                    ");
}  //end clear display for(j = 0; j<=3; j++)
// function:
void lma_print_real(double value)
    intpart = (int) value;
    fracpart = (value - intpart)*1000;
    LCD_PrintNumber(intpart);
    LCD_PrintString(".");
    if(fracpart < 10) LCD_PrintString("0");
    if(fracpart < 100) LCD_PrintString("0");
    //if(fracpart < 1000) LCD_PrintString("0");
    //if(fracpart < 10000) LCD_PrintString("0");
    LCD_PrintNumber(fracpart);
}  //end lma_print_real
int main(void)
    //initialize display
    LCD_Start();
    CyGlobalIntEnable; /* Enable global interrupts. */
    lma_clear_display();
    LCD_Position(0,0);
    LCD_PrintString("initialize          ");
    CyDelay(500);
    //initialize variables
    n = 0;
    x = 0;
    y = 0;
    xy = 0;
    x2 = 0;
    xsum = 0;
    ysum = 0;
    xysum = 0;
    x2sum = 0;
    zero = 0;
    //set op amps, A2D, and D2A
    OpAmp_grn_in_Start();
    OpAmp_wht_out_Start();
    D2A_Vout_Start();
    D2A_Vout_SetSpeed(D2A_Vout_HIGHSPEED);
    D2A_Vout_SetRange(D2A_Vout_RANGE_4V);
    LCD_Position(0,0);
    LCD_PrintString("D to A started      ");
    CyDelay(500);
    A2D_wht_pot_Start();
    A2D_wht_pot_SetPower(A2D_wht_pot__MEDPOWER);
    A2D_wht_pot_SetResolution(A2D_wht_pot__BITS_8);
    A2D_wht_pot_StartConvert();
    A2D_grn_snsr_Start();
    A2D_grn_snsr_SetPower(A2D_grn_snsr__MEDPOWER);
    A2D_grn_snsr_SetResolution(A2D_grn_snsr__BITS_8);
    A2D_grn_snsr_StartConvert();
    //step through output voltages from 0.75 to 3.23 V
    //digital range 47 to 202 or 0.75 V to 3.32 V
    //increment +1 yields 156 data points
    //increment +5 yields 32 data points
    LCD_Position(0,0);
    LCD_PrintString("for loop            ");
    CyDelay(500);
    for(k = 47; k<=202; k = k + 5)
        D2A_Vout_SetValue(k);
        CyDelay(500);
        //get pot value
        //wait for end of conversion
        do
            {temp = A2D_wht_pot_IsEndConversion(A2D_wht_pot_RETURN_STATUS);}
        while (temp == 0);
        CyDelay(200);
        x = A2D_wht_pot_CountsTo_Volts(A2D_wht_pot_GetResult8());
        //get sensor value
        //CyDelay(200);
         do
            {temp = A2D_grn_snsr_IsEndConversion(A2D_grn_snsr_RETURN_STATUS);}
        while (temp == 0);
        CyDelay(200);
        LCD_Position(0,0);
        LCD_PrintString("convert finished    ");
        CyDelay(500);
        y = A2D_grn_snsr_CountsTo_Volts(A2D_grn_snsr_GetResult8());
        //linear regression calculations
        n = n + 1;
        xsum = xsum + x;
        ysum = ysum + y;
        xysum = xysum + (x * y);
        x2sum = x2sum + (x * x);
        LCD_Position(0,0);
        LCD_PrintString("k = ");
        LCD_PrintNumber(k);
        lma_print_real((double) (k * 4.08/255.0));
        LCD_Position(1,0);
        LCD_PrintString("x = ");
        lma_print_real((double) x);;
        LCD_Position(2,0);
        LCD_PrintString("y = ");
        lma_print_real((double) y);
        CyDelay(10000);
    } //end for(k = 47; k<=202; k = k + 5)
    //find slope and intercept
    num = n * xysum - xsum * ysum;
    den = n * x2sum - (xsum * xsum);
    slope = num/den;
    num = ysum * x2sum - xsum * xysum;
    intercept = num/den;
    zero = (-1 * intercept / slope) - 2.5 ;
    //display results
    LCD_Position(0,0);
    LCD_PrintString("sensor data         ");
    LCD_Position(1,0);
    LCD_PrintString("slope = ");
    lma_print_real(slope);
    LCD_Position(2,0);
    LCD_PrintString("int = ");
    lma_print_real(intercept);
    LCD_Position(3,0);
    LCD_PrintString("zero = ");
    lma_print_real(zero);
    CyDelay(5000); //5 second pause
} //end of main
/* END OF FILE */
the pinouts for the op-amps were assigned by PSoC Creator
the input range of the SAR AtoD is Vssa to Vdda (single ended)
the reference is thus forced to internal and the reference is 2.5 V
This is the observed results - - left column is the d to a theoretical value, which agrees with meter measurement thereof,
the right column is a to d output as seen on the LCD:
0.752 0.840
0.832 0.938
0.912 1.016
0.992 1.113
1.072 1.191
1.152 1.289
1.232 1.387
1.312 1.465
1.392 1.543
1.472 1.641
1.552 1.719
1.632 1.816
1.712 1.895
1.792 1.992
1.872 2.070
1.952 2.168
2.032 2.246
2.112 2.344
2.192 2.422
2.272 0
2.352 0
2.432 0
2.512 0
2.592 0
2.672 0
2.752 0
2.832 0
2.912 0
2.992 0
3.072 0
3.152 0
3.232 0
this is the graph of the data, without the the SAR produced 0s
the question is - what happened to the SAT output when it went above about 2.5 V?
why did it go to zero?
what did i miss/do wrong?
i did some testing
i think the error is in the SAR API GetReults8
using an 8 bit SAR with GetResult8 gives the bad data after about 2.5 V
using an 8 bit SAR with GetResult16 works past 2.5 V
Agree, I have reported this to Infineon.
Post # 18 gives a working example when using GetResult16()
Regards, Dana.
LaTeX Commands Quick-Menu:
