[SOLVED] rs232 communication with 8051 , sim300 and gps reciver
debabrta kar
Member level 5
india
hi, i want to interface both gsm modem SIM300 and gps reciever with 8051 and i am using only 1 max232 ic . i have connected 11 and 12 number pin to microcontroller tx and rx pin respectively and i want to know how to connect with gps receiciver . please help me with approprriate circuit diagram... thanx in advance
Hi there,
This link might be helpful for you.
regards,
yes , i had checked on your link...but actually i said that i want to know how to connect both gsm and gps with microcontroller not seoparately....so please gide me....
I am sorry and helpless.. How many RS232 port avaiable on your processor? If it two or more you can connect it easily. Only one is there then you can use either GSM or GPS.
i am using AT89S52 microcontroller which ix having 1 serial port......
    V
if u want to send message (lat and long information) using sim 300 then connect GSM to TX pin and GPS to RX pin of microcontroller. recieve GPS data then transmit the required data using GSM.
i want to sent signal from modem sim300 to mcu...so both tx and rx pin will be dedicated for gsm modem.....so how to interface gps.......plz give sum ides.....
We are a manufacturer of modem, and distributor of Wavecom module for 10 years.We hope you can tell me more about your problem and solve it together.
We have the capacity of desinging and making modem, so we also has the ability to do it
Best wishes
skype: evan_lee25
mail:musicforevanlee@gmail.com
Hi venkadeshm
Multiplexing ...?? how do you do Multiplexing in UART??
Best regards,
Best wishes
skype: evan_lee25
Hi venkadeshm
Thanks a lot. I forgot that idea and you reminded me again.
Best regards,
yes i got the result by using 1/9600=104microsecond of delay we can recive the data frame of rs232 with any pin of any port except p3.0 and p3.1 ........
