RP2040-Zero Powered Laser Range Finder with GUI and a 2.4" TFT Display
Hesambook
Full Member level 2
In this article/video, I used an RP2040 Zero board, a VL53L0X Laser time-of-flight ranging sensor, and a 2.4” TFT display to build a graphical laser rangefinder unit that can be used to monitor the distance, check the liquid level, etc. The board is also equipped with a relay and a buzzer that allow the user to provide distance-related acoustic signals or activate/deactivate an external device, such as a pump, brake, etc.
Source: https://resources.altium.com/p/rp2040-zero-powered-laser-range-finder-gui-and-24-tft-display
Specifications
Input Supply Voltage: 5V-Regulated (USB Type-C or wire-to-board connector)
Current Consumption (maximum): 200mA
Measurement Range: Adjustable 30mm to 1000mm (2000mm long range)
Distance Resolution: 1mm
Sensor Error: 3% (best) to 10%
The board is really compact. I think an enclosure will make it safer.
Yes, I had no time to design an enclosure for this, but Yeah certainly it is the way it should be. go for it
LaTeX Commands Quick-Menu:
