neazoi
Advanced Member level 6
More harmonics are better! the whole purpose of the device is to produce as many of them as possible. If you insert the filter all you will do is halve the DC bias available so you may then have to resort to a voltage quadrupler to get back where you started!
I doubt a 1N23 will work any better and it may be significantly worse. The property you need in the diode isn't it's microwave performance but it's rapid switching action. The harmonics are generated by the rapid turn-on and turn-off as it moves to and from conduction, that's why fast and step recovery diodes work best.
Brian.
Hello,
here is the final schematic.
You were right about the filter, it reduces too much the bias voltage and I have not noticed a significant improvement in "unwanted" harmonics generation. The voltage doubler produces about 36v loaded by the diode, which is brought up to 0v with the potentiometer. The harmonics attenuation is great under this range, the full screen in my analogue spectrum analyzer. The harmonics and level depend also on the input frequency, as well as the input level, as these affect not only the harmonics diode but also the doubler response. I have not made any serious measurements yet, but overal very satisfied by such a simple circuit, a great way to produce test signals for the uhf/microwave, if efficiency does not matter.
I wonder, if I use a single diode passive mixer and connect it to the harmonics generator, will the mixer be able to shift up generated frequencies even more...it should?
