Help
Advanced Member level 2
- Joined
- Feb 15, 2005
- Messages
- 617
- Helped
- 7
- Reputation
- 14
- Reaction score
- 3
- Trophy points
- 1,298
- Activity points
- 7,065
If the OUT signal couse the 7404 signal not stable, what can i do?
Please check the graph that you wan? If not please me know again.
Thank You.
We only can use idle_1 but i am sure the INT0 is '1' when we never connecting the OUT because i got measure it (between the OUT and INT0 i have add one driver Gate 7404, i think from there we already invert the signal already.). Now i also worry whether the OUT signal is stable on Hi/Lo not when no key pressed. If not the 7404 will hap-logic(sometime Hi, sometime Lo). May be because of that we get the idel_1 no data graph. I confirm it again then let you know.budhy said:1. You use idle_1, it mean when no key pressed the voltage at INT0 is '1'. But why there is idel_1 no data graph? Does it mean without any key pressed there are still a pulses stream on OUT pin?
The CYCLE(blue bar) is nothing, it just let us know the number Buffer data. We have 70 data in buffer.budhy said:2. What is the meaning of CYCLE (blue bar)?
Thank You.
