Resampling scaling truncating Matlab data file
michaelScott
Junior Member level 2
I need to perform the conditions to the data file below on the matlab. can you help me how to do that.
Data File = 2x460800
Conditions:
1.) The scaling defined in the PhysioNet .info files for each PhysioNet data file was applied to each raw data file.
2.) The data were resampled to a common rate of 128 hertz.
3.) Each data file consisting of two ECG recordings was separated into two separate data records.
4.) The data length was truncated to a common length of 65536 samples.
