Reproduce Radiation Pattern from the Anechoic Chamber Pattern File!
imtiaz369
Member level 2
Member level 2
Hello, everyone. I received a pattern file from the anechoic chamber. However, I am unable to reproduce the radiation pattern from this file. The theta value ranges from 0 to 180 degrees, so how do I plot a full 360-degree plot?
I have attached a sample file. I want to do it in either Matlab or Python.
Is there anyone who can help me better understand?
Thank you.
  • FF 1800_000MHz.txt
If your phi angle goes the full turn from 0 to 360 degree, you only need theta from 0 to 180 degree. Hopefully the picture helps to understand that.
LaTeX Commands Quick-Menu:
