relation between snr and Eb/No
relation between eb/no and snr
Hi
may be someone can explain the connection between the C/N and SNR?
Thank you
c/n snr
Hi
I aslo want to know more abt this matter
Thanks
difference between snr and ebno
The question about SNR (also referred as S/N, C/N, or (Co+No)/No ) relation to Eb/No typically arises in link budget analysis. E.g. in satcom the demodulator Eb/No threshold for given FEC can be found in datasheet / manual of the unit, while according C/N required to input into the link budget is often unknown.
Here's what I found in page B-2 of manual of CDM600 satellite communications modem by Comtech EFData:
Eb/No = 10*log(10^((Co+No)/No)/10)-1) - 10*log(FEC Code Rate) - 10*log(bits/symbol)
• Eb/No and (Co+No)/No are expressed in dB
• Bits/symbol = 1 for BPSK
• Bits/symbol = 2 for QPSK
• Bits/symbol = 3 for 8-PSK
• Bits/symbol = 4 for 16-QAM
eb/no formula
refer to this link : "Channel Capacity in AWGN"
h**p://
difference between snr and eb/n0
pthoppay said:
Signal Power(S)= (no.of bits)* Eb
N= No* B(bandwidth of signal)
So
S/N= (n*Eb)/(No*B)
Regards,
Thoppay
hi just wondering that Eb is signal energy per bit. so how come signal power= no of bits * Eb
shouldnt it be signal energy=no of bits* Eb?
or is it so that energy and power have same meaning when it comes to signals?
elaborate please
snr to eb/no
S/N = signal to noise ratio.
when E comes in to the picture means enargy and energy = power * time. so the term related to time or 1/time must be included. if we want in decibal then multiplication will be converted in to addition so
we can say that Eb/No(dB) = S/N(dB) + 10*LOG(BW(Hz) / BitRate(Hz))
eb no formula
A good explanation you will find at:
S. Benedetto, M. Mondin, and G. Montorsi, "Performance Evaluation of
Trellis-Coded Modulation Schemes," Proceedings of the IEEE, Vol. 82, No. 6,
pp. 832-855, June 1994.
On page number 836. I am implementing a BER calculator to M-QAM systems and defronted me with this same problem.
There are other methods, but I believe to QAM this may be OK.
snr es n0
gurpreet said:
can anybody tell me the exact relationship between SNR and Eb/No?
gurpreet
Can someone confirm me if the relation:
Eb/No = S/(N * log2(M) ) is correct?
Because I achieved the following
C/N = SNR * 1/log2(M) + 10 log (4) in the case of using 16-QAM modulation..
And I would like it someone could confirm it to me!
Thanks in advanced
difference between c/i and eb/no
Hi
In an M-ary system :
Es/N0 (dB)=Eb/N0(dB) +log2(k) ,where k=code rate×log2(M)
(when coding is not used ,code rate is equal to 1)
Es/N0(dB)=10log10(Tsymbol/Tsampling) + SNR(dB)
hence , the realtion between Eb/No and SNR is given by :
Eb/N0(dB)=SNR(dB) + 10log10(Tsymbol/Tsampling) - log2(k)
regards
snr and eb no
amihomo said:
Hi
regards
Thanks for the explanation.. but I'm still in doubt about my formula.. if it is correct or not my direct relation between C/N and SNR.
I found the following paper in the page of Rhode & Schwarz but I don't know if I can apply the 1st formula because of the roll-off factor once I'm using DVB-T system.
And I need to be certain of the formula to allow me to compare my results in SNR scale with the DVB-H results I have in C/N scale.
Any help on my subject will be welcome!!
Thanks in advanced!
Cheers
eb no equations
if the SNR and Eb/No is same then why we say better communicatiuon sysytem is with less Eb/No and large S/N is better..
how its possible...........
e?n and SNR is not same.plz comments
eb n0
the difference between them is PG.
relation between snr and eb/no
please can someone tell me about snr or eb/no in MIMO OFDM, for example i want to compare the performance (ber vs snr) of direct channel ofdm with 2x1 stbc-ofdm. how to make it comparable.
cheers!
snr eb/no c/no
i use it thanks for all ur reply
Snr = signal power / noise power
= Ps/Pn
= Ps/(No*W)
=(R/W)* Ps/((R/W) * No)
=(R/W)*Eb/No.
Since additive white gaussian noise is used bandwidth W here corresponds to the bandwidth of the signal.
very nice informations , than you very much
