Maitry07
Full Member level 2
Hello support team,
I am using high speed data converter , in which there is an inbuilt RF-ADC along with DDC. which can directly digitize RF input and generate I and Q samples accordingly at DC.
Below is the example.
RF frequency=35 MHz, NCO frequency =34 MHz, DDC output = I and Q samples at 1 MHz.
Now I am capturing these I and Q samples in signed decimal format. and stored it in the excel.
My RF input power: -25 dBm
DDC output I and Q sample example when my RF input is -25 dBm
I_sample (signed decimal value) = 1785
Q_sample (Signed decimal value) = 687
Pdbm = 10log(I^2+Q^2) = 65.6 dBm
So, is there any calculation I am missing? PdBm should come -25 dBm. My DDC output is in the FIX16_0 format, from which I have taken the signed decimal values. could you please guide on this?
Is there any requirement to scale down the I and Q samples by fixed scaling factor to get the correct pdBm result?
