questions on current noise simulation
hyleeinhit
Member level 3
Member level 3
U.S.
Hi, guyes,
I ran into problem when I simulate input inferred equivalent noise with AMI 0.5um CMOS process with cadence spectre. I followed noise analysis note in https://www.ece.tamu.edu/~spalermo/ecen474/noise_sim_notes.pdf and set the flicker noise simulation parameters:
[For NMOS model, add the following to the end of your model :
KF=0.276E-25 &
AF=1.53 &
For PMOS model, add the following to the end of your model :
KF=0.466E-26 &
AF=1.61]
In noise analysis, I set iprobe3 as output and Iin as input current source. Iin DC value is set at 10nA for DC bias; Iin AC magnitude is set at 1 for noise simulation.
To display the input referred current noise, I selected RESULT->DIRECT PLOT->EQUIVALENT INPUT NOISE. However, I got quite strange input referred current noise result: Noise in high freq. domain is higher than that in low freq. domain. In theory, should low freq noise be higher than high freq noise because of flicker noise?
Anyone can help me out?
I got quite strange input referred current noise result. Noise in high freq. domain is higher than that in low freq.
What's strange with this result? Any MOSFET has it, review your text books. Gate capacitance converts voltage noise into current noise.
what is the transfer function of the circuit? Is it working correctly? Input referred noise can look unusual sometimes as it is taken by applying the input-output transfer function to the output noise in reverse. If the frequency response of the system is unusual then the output noise can look sensible but input referred can look strange.
Keith
Because of flicker noise, should low freq noise be higher than high freq noise?
Keith
Sound reasonable.
Is there any problem in my noise analysis setting?
Voltage noise yes, current noise no. See a typical MOSFET noise characteristic:
Thanks. I understand it a little bit. Define input referred voltage noise as Vnin, and input capacitance as Cin, input referred current as Inin.
Inin=Vnin*j*w*Cin
Thus, high freq Inin component is larger than low freq Inin component.
BTW, I find a different image about input referred noise plot from
https://www.planetanalog.com/document.asp?doc_id=528133
. Any comments?
