gdhp
hi jerryzhao lovseed and others
i am designing a 10-bit DAC. Its lowest power supply is 2.5V. And the output range
is 0-1.4V, LSB current is 36uA. In order to veryfy the INL<1LSB, i use the
cascode current source, the current source size is 12/2u. So the whole area of
current source array is too large to bear. But if decrease the size of unit current
size, when output is beyond the 1.0v, the cascode mosfet enters into linear. I
simulate the output impedance influence by dc sweep the output voltage, find the
output current is derease more than 1LSB when output reach 1.4V( is this
simulation method right?).
Another i try to use a single current source, when its size is 9/2, it also give much INL error.
Because my DAC area is limited, so the large size of current source mosfet is
impossible. But the INL<1lsb and DNL<0.5lsb requirement still exists.
So can you and others give me some suggestions about this problems? Is there
some method or paper deal with it?
Thanks a lot!
GDHP
Thanks a lot!
GDHP
