moh_hafez
Newbie level 1
complex polyphase filter
I have made a 3rd order complex filter , when performing noise analysis using cadence , i put noise sources at both the inputs of I and Q channel , and saw the output noise at the I or Q channel , it was 45nV/sqrt(hz) . when i measured the input referred noise at the I or Q channel , it was about 100nV/sqrt(hz) although the gain is 0dB .
So does this may be bec. of Cadence when calculating Noise , as it doesn't see the phase difference bet. the noise sources of the I and Q channel (as it doesnt care for the data in ac sources when performing noise analysis) and hence it doesnt see the 0dB gain which depends on the phase shift bet. I and Q inputs .
So is the solution that i get the output noise using cadence and then calculate the input referred noise based on my understanding that the input will be the same as the output .
