Question about El-Cheapo Programmer
Jack// ani
Advanced Member level 3
Hi all,
I found el-cheapo programmer by Myke Predko quite easy to build, but I have some confusion regarding schematic. There it is all….
1. Is there a junction in the schematic encircled with red circle? That is between pin10, pin9 and pull up resistor(R7).
2. Can I replace 78L08 with a LM317 variable voltage regulator, adjusted to give 8volt output.
Thanks a lot.
I believe the answer is yes to both of your questions. It seems that the data needs a pullup and 78L05 has almost the same current characterisitc as LM317.
To make sure everything is OK, add a 22-100 uf cap to the output of the 317 and you will be OK.
BR,
/Farhad
hi i have bought the book of Mike Preko tittle programming and customizing pic microntroller it is a thick book in the book there is a pcb and software for soldering stuff. i did follow the instruction but it won't work i try to email ask the author but for the past six month no reply yet.
i used all part number exactly as describe in the book
