Question about AT89S52 microcontroller
definetely you can use it without encoders and decoders, only if you take care of encoding and decoding in the software. its 100% possible , but may not be easy for begineers.
Thanks for the response but the code is already written
And about my second question what are the "write/edit" in the schematics? =) thnx!
this maybe for enabling encoding the data after the data is written completely. but this depends on the designer how the code is implemented. if you have the code then put it here, then someone can explain you.
Thanks for ur response.
I meant the edit and send on the circuit diagram what are they hardware?dip siwtch?buttons?
Yes they are push to on dip buttons (may be pcb mount) but rest of the stuff and related code is what needs attention.
what do u mean the rest needs attention? and I am going to use breadboard instead of pcb
this project is working one i know where the problem is
there is a problem?xD where is it?
edit and send is two simple push button switches did you complete the circuit diagram then you will notice where the problem is i want you to rectify where the problem is but don't worry i will help you sure .
can u tell me, what is wrong? Bcoz I still didnt buy all components
code is wrong
---------- Post added at 13:22 ---------- Previous post was at 13:20 ----------
you want to change hardware or software ? if you don't want to change hardware you need change program or if you want to change hardware program is ok .
no they are different the one i have shown you works in uart mode but the one you have works on machester coding techniques ( you need encoder and decoder for data transfer)
Hm , what are part No.s of ur tx and rx . If I cant find, what are the numbers of encoder and decoder I can use?
My Tx and Rx are TX433 and RX433 (ASK)
OR does can I do that thru software? That would be great help if that was the solution =)
thanks!
Still waiting for ur respond, because I have to buy components thanks =)
i have also tried this project one year ago but after changing transmitter and receiver i succeed just buy the modules i have shown you that module works on uart mode
