Quad LVDS IC Family
imran99
Junior Member level 3
Pakistan
The AS1150-52 are first products in the family of low-voltage differential signaling (LVDS) ICs. The chips are suitable for applications requiring high-speed data transmission.
Supply current of the chips has been halved to improve power consumption of LVDS interfaces. Offering a data rate of up to 500Mbps, the AS1150/51 receivers consume a supply current of only 5mA while the AS1152 consumes 4mA. Each AS1150/51 receiver accepts four LVDS input signals conforming to the ANSI TIA/EIA-644 LVDS standard, and converts them to low-voltage LVTTL/LVCMOS output levels. The AS1151 also features integrated termination which eliminates the need for four external resistors. The AS1152 converts four low-voltage LVTTL/LVCMOS signals into LVDS output signals conforming to the ANSI TIA/EIA-644 LVDS standard.
Designed with flow-through pin-out, the AS1150-52 family reduces crosstalk between channels and simplifies board layout. With a small pulse skew of 300ps for the receivers and 350ps for the driver, they are suitable for high-resolution imaging and high-speed interconnection applications. The quad LVDS family works in a temperature range of -40 to +85, from a single +3.3V supply. They are available in a 16-lead TSSOP package.
austriamicrosystems, austriamicrosystems - analog IC, analog semiconductors - Standard IC solutions and ASICs
