aq_mishu
Full Member level 4
![Full Member level 4](/styles/images/ranks/flevel1.gif)
I just found this...
now can somebody help me to alter this as per my "specific" requirement?? Basically this is implementing a digital POT type thing instead of our old analog (and the easy one too)...
But I need the following::
Switch ON> Wait for 2sec>slowly glow and make full ON in around 2 sec. But this is auto... I mean I'll turn on the main power of the entire ckt... it will get VCC and on the power on, the uC will get power, the AC line will be connected through relay, the dimmer will start to work and the light will light up...
once I cut the power off... it's just plain power cut from the relay for 220V, and so the uC. (Here relay is just for fed the 12VAC through an isolation transformer)
Mishu~
Mishu~
