emaniac
Member level 1
Designing a push pull converter using SG3525. I have 400watt, 350V secondary transformer( I didn't design one, but purchased). When I connect Load there is a huge drop in voltage.
When I check the Voltage at the output of the connection above, I have 350V. When i add a capacitor (180uF, 450V) the voltage drops to 295V.
Diodes used - MUR460
Now if I add a Load (15 Watt ), Voltage drops to 160V at the output. As mentioned in other Post I checked if Battery Voltage is dropping, But No, Battery Volt is 12.
Current from Battery is 0.9A @12V
Current to Load is 0.05A @ 160V
And Yeah, PWM duty is 50%
I don't Know which part of the design needs attention.
Regards,
Regards,
