DasPreetam
Mosfets without a 100 ohm resistor results in a simulation error. (Wouldn't they burn out due to excessive current without the resistor ?) How to determine how much power will the mosfets deliver ?
In India, we have 230V mains. If the mosfets are producing 26V, then how come the output be 92V ?
Your Mosfets without the 100 ohm resistors produce a peak-to-peak output of about 26V then the 20:1 transformer produces an RMS output voltage of only 92V instead of 120V and the voltage will drop as the battery voltage runs down.
