PSS convergence in PLL simulation
Wrong.
Surely confirm and study your PLL.
Show me true comparison frequency and divide-ratio.
Are they truely 19MHz and 128 ?
It is too early for you to go to PSS Analysis.
After lock time, the VCO output frequency has some spurs due to the nonlinearity of the charge pump.
I think this is the reason.
It can never be.
2440MHz-2432MHz=8MHz is too large.
Please suggest me the type of analysis, to verify the PLL.
Transient Analysis.
According to https://i.imgur.com/YXkq61K.png, fout=2433.7MHz at 4.6usec.
Yout PLL is far from locked state with ~10usec.
Run Transient Analysis of Tstop=500usec.
Then show me fout at 50usec, 100usec, 150usec, 200usec, 250usec, 300usec, 350usec, 400usec, 450usec and 500usec.
Thank you for your kind consideration.
I will reply to you after doing what you have suggested to me.
yes, the comparison frequency (reference frequency) is 19 MHz and the divider ratio is 128 ( for divider I have used 7 stages of cascade TSPC latch).
fout frequency at
50us : 2431.3MHz
100us : 2433.5 MHz
150us : 2433.5MHz
200us : 2433.2MHz
250us : 2433.3MHz
300us : 2434.9MHz
350us : 2434.4MHz
400us : 2435.1MHz
450us : 2432.9MHz
500us : 2431.1MHz
It seems Tstop=500usec is not enough to be locked state.
500usec is nearly equal to 10000cycles regarding your comparison frequency, 19MHz.
Try Tstop=1msec.
BTW, you have to save minimum node or current in PLL simulation.
Don’t save unnecessary data such as device parameters, subcurcuit infos, etc.
Show me netlist except for circuit descriptions.
ok, I will try with 1msec and update you with the result
netlist:-
simulatorOptions options reltol=1e-3 vabstol=3e-5 iabstol=1e-11 temp=25.0 \
    tnom=27 multithread=on scalem=1.0 scale=1e-6 gmin=1e-12 rforce=1 \
    maxnotes=5 maxwarns=5 digits=5 cols=80 pivrel=1e-3 \
    sensfile="../psf/sens.output" checklimitdest=psf
tran tran stop=1m errpreset=moderate write="spectre.ic" \
    writefinal="spectre.fc" annotate=status maxiters=5
finalTimeOP info what=oppoint where=rawfile
modelParameter info what=models where=rawfile
element info what=inst where=rawfile
outputParameter info what=output where=rawfile
designParamVals info what=parameters where=rawfile
primitives info what=primitives where=rawfile
subckts info what=subckts where=rawfile
save fout
saveOptions options save=selected
These vabstol=3e-5 iabstol=1e-11 are different from default values.
Why do you set vabstol and iabstol as these values ?
Delete these lines.
