krashkealoha
Full Member level 1
- Joined
- Jul 3, 2004
- Messages
- 99
- Helped
- 15
- Reputation
- 30
- Reaction score
- 7
- Trophy points
- 1,288
- Location
- 21.402, -157.739
- Activity points
- 1,292
pspice for sic bjt
You state that the SiC Vbe turn on voltage is 2.7V, but in a previous message ("bjt modeling") you had output characteristic curves (Ic vs. Vce) where the transistor has collector current below Vce=2V. Are the output characteristic curves the same transistor? If they are the same, how is it possible to get the collector current less than Vce=2V when the turn on voltage is 2.7V?
Yes, the 4140 should be able to test the bjt. You can step the forcing voltage and measure a current. There are examples of how to measure a diode, and a mosfet transistor in the manual/application notes. If your turn on voltage is 2.7V, then you should apply a large Vce voltage (greater than 5V).
