PSFB converter with resonance phenomenon
snvl0228
Junior Member level 1
I'm designing PSFB converter and simulating with PSIM simulation tool.
Since all the components in PSIM are level 2, ESR, ESL, DCR, etc. are all included.
At this time, a resonance phenomenon occurs between the leakage inductance of the transformer and the junction capacitance of the secondary rectifier diode.
Does this phenomenon also occur in reality?
Input voltage: 800Vdc / Output Voltage 300Vdc / Switching Frequency: 100kHz / Output Power: 15kW
I found that in real life such parasitic oscillations decay faster than in simulation. Real components have higher HF losses. But if you want to suppress it completely, add RC snubber.
You mean just ringing, right..??
An example waveform would be helpful in describing the problem. Could be that you just need RC snubbers across the output diodes.
In the simulation you can see something like this. Impossible in real life. Q is over 500
Thanks. What is Q..?? Could you let me know..??
--- Updated ---
Thank you. I didn't see your advice.. sorry...
Really good inductors, really good filter caps
and really good switches make high Q. The
corner frequency for output filter is traditionally
low and the control loop has to stabilize the
mess.
Write your reply...
LaTeX Commands Quick-Menu:
