[SOLVED] Project to replace CY7C64613 in the ICD2
icd2 877
Preliminaty version of PIC ICD2.5 - **broken link removed**
mplab icd2 diagram
I have finished the schematic. Please check for errors. Probably have placed too many LED's, their function is:
LED1 - USB Connected
LED2 - Error
LED3 - Busy
LED4 - VDD is present on the target device
LED5 - VPP is present on the target's MCLR
LED6 - VPP source is working
LED7 - Power LED
J3 is to select ICD's power source (USB bus/target device). I don't know, why original ICD2 uses 74HC125 and 126, i have copyed this from the original's schematic. Anyone knows what is on the pin 6 of the original ICD2?
I hope, the board will be finished on the next weekend, but it's not sure(if i have test, that has higher priority). The schematic was drawn in Eagle, if you want, i can also upload the source files.
usb whith pic18f2455
As mentioned, this site: **broken link removed** has a fully working ICD2 with 18F4550. Because I speak the language, I can translate some facts for you:
Author says, he had to reverse engineer first 128Bytes of the Bootloader HEX, that took him two weeks. Among other things, he mentions RB7 as a Bootloader/OS switch. This article is only a preliminary sneak peak, he will publish complete solution 'soon'.
Let's see how long will 'soon' take him...
mc34064a 50v
ICD2 new firmware posted
potyo2 rev2
Hi. Brem. My icd never corrupt PIC18F4550 flash. You mean that program in the 4550 gets corrupted after a quick disconnect/reconnect from MPLAB or cable?
Best Regards.
pic18f8722 mplab source external sram
Jay what did he reverse the bootcode from? Since the supplied files does not contain it. He got a new ICD2?
icd2_clone_4550_-_pics
movingbait: That is very old...
Zedman: Well, he only says, that he modified the OS HEX file. He certainly didn't buy a clone. He says he reverse engineered it, meaning he must've looked into Windows driver or something.
I wrote a request into his discussion board, to publish his HEX. He replied that 'the HEX from EDAboard' is incorrect, that the OFFSET is ok, just the changes are not done correctly.
blown up icd2
I wonder how he get that 128 byte out of the windows binaries...
Anyway it's useless to modify BOOT or OS images because they'll get overwritten by MPLAB. All we can modify is the 0x0000-0x0080 area.
Added after 2 minutes:
Maybe it's a bla-bla only ;)
Added after 3 minutes:
Or if he patched the .bin files it's useless too, because what if new version comes out?
18f4558 usb programing
Jay.slovak: No, nothing modified in OS.HEX, only in BOOT.HEX is rewrited first 128B. Your translation of my topic on www.mcu.cz is realy very very good :cry: :cry: :cry:
Zedman: maybe..... but schematics, pcb and bootloader is finished and working :D :D
icd2 malaysia
Yes, my bad, I switched them in my head when I was translating your article. Assuming you are Kosta :D
18f4550 icsp without icd2 usb
This is start of your post icd24550.hex - its corect??? :D:D:D:D:D:D:D:D:D:D:D:D
:1000000015EF00F0FFFFFFFF04EF14F01200FFFFF9
:10001000FFFFFFFFFFFFFFFF64EF00F01200FFFF95
:10002000FFFFFFFFFFFFFFFFFFFF0001000EE16E7C
:10003000E26E000EE66EE2500808FBE160EF00F0B1
programming interface pic24fj32
I don't wanted to be harmful or anything sorry. :/
Please if the hex posted by me is not working than talk to me! Iam only a human, who make mistakes.
Added after 1 minutes:
Anyway you can post your solution/ideas here as we did.
0xefeb
Potyo:
74hc125 and 126 is bus control circuits. Whit those IC's we can decide in what direction the data is moving.
When we put state 1 (5 volts) to for examble IC3D pin 13 and IC4D pin 13 (in your schematics) other goes to so called 3. state (high impedance state) and which one is in that state doesn't let anything pass..
This is how we can change the direction of data whitout that we have to disconnect these two devices.
Correct me if I'm wrong. People make mistakes :D
Added after 28 minutes:
BTW!
I think that you have to connect pins 1 and 2 in IC4A and 5 and 6 in IC4B to the ground. Those may have start some kind of vibration in IC which could distruct the data line..
icd2 dg412
Petarpav: it's cable, but i think Zedman found a good solution.
pic24fj32ga002 avdd
Eureka!
It turns out my crystal was oscillating but my cheap probe killed the oscillation and tricked me into thinking it was wrong. I wasn't sure if my usb lines were correct so I made a little header where I could reverse them and, sure enough, it popped up in device manager as soon as I switched the lines :D Does that device string look correct? I am currently using Zedman's hex file.
I now get a "ICDWarn0054: MPLAB IDE has lost communications with the MPLAB ICD 2. Would you like to attempt to reconnect?" error in MPLAB... am I ready to add the 877a now? I think I am 8)
icd2.ini
ravimarcus said:
This DC DC converter works for me. The 10F200 is used as an oscillator. The GREEN LED may be replaced by RED LED if you need a lower voltage. The LED also works an a power on indicator.
Cheers
Ravi
Hi Ravi and hi to all. Which frequency 10F200 provides?
unicorn 18f4550
About 90KHz. All you need is the code below :)
main clrwdt
bsf gpio,osc
goto $+1
goto $+1
bcf gpio,osc
goto $+1
goto $+1
goto main
You can play with the frequency and duty cycle to get different voltages. The PICmicro here is a glorified oscillator.
If you change the 330 uH, then the frequency also need to be changed.
Cheers
Ravi
16f877 vpp voltage drop
I hooked up the 877a last night after I got the usb working and now when I try to download the OS it says that it's not an ICD2. I believe it read product ID 0x00 which was an ICD (1)? Does it sound like I'm just not getting data from the 877?
18f8720 target id not found with mplab
Yes, it's right, but i think, we can realise this with cmos switches(probably they have too high impedance ~ 70Ω). I will connect those pins to a fixed potential when making the pcb.
