[51] Programming in C language for 8051 Micro Controller
You can take data as well, with help of global variable (or) function pointer.
For your requirement already suggested to use global variable.
I have already mention i tried using Global variable and i have post my code also...
But i can't success using global variable...
so please give me some example code with ISR so i can understand easily...
Just observe it:
Code C - [expand]
8
9
10
11
12
13
14
15
/* Declare global variable like this */
volatile int u32_gvar = 0;
/* use it in interrupt handler like this */
interrupt_Handle()
            /* Assign the data to global variable like this*/
            u32_gvar = temp; //temp is any local data
int main()
      /* you can use that data here for your operation */
      u32_gvar++;   // it is some example operation
I have to write Return Statement in each and every subroutine for go back to main routine?
I want to do SPI communication using AT89C55WD Microcontroller using C language.
please give me some example code without SPI register (using GPIO pin).
If you don't want to return from subroutines every time, just declare a structure
with required members then declare a global variable with that structure type.
If you update the global structure variable, it automatically accessible in main function
and other functions also...
k.. thanks...
Hi jignesh,
Looking like there is no support for SPI protocol in this controller, can do it with GPIO.
for that should write a driver with GPIO's, it should work like normal SPI communication.
if driver functionality is implemented with GPIO's, then that concept is called as bit banging.
@chandu,
Thanks for your reply...
I know this controller is not support for SPI protocol...I have already written my code assembly language for this protocol and it is working successfully but now i want to move to C language so i wrote and convert as C rules but i cant get my result proper.
When i see waveforms on CRO on my two different pins then i saw there is no synchronize between two different signal after using of C language.
so i require some example program so i can verify it with my program.
My program is shown as below.
void main()
			lcd_ini();
			lcd_command(0x01);
			delay(5);
			initiate_adc();
			while(1)
			cycle_count();
			lcd();
void cycle_count()
			command = 0x0A;
			read_adc();
void read_adc()
			cs1 = 1;
			sclk = 0;
			sdelay(0);
			cs1 = 0;
			sdelay(0);
			ACC = command;
			write_adc1();
			sdi = 1;
			read_adc1();
			adc24 = ACC;
			sdi = 1;
			read_adc1();
			adc16 = ACC;
			sdi = 1;
			read_adc1();
			adc8 = ACC;
			sdi = 1;
			sdelay(0);
			cs1 = 1;
			sdelay(0);
void read_adc1()
			int i;
			ACC = 0x00;
			for(i=0;i<7;i++)
				lsb = sdo;
				ACC = ACC << 1;
				sclk = 1;
				sdelay(0);
				sclk = 0;
				lsb = sdo;
				ACC = ACC << 1;
				sdi = 0;
				sclk = 1;
				sdelay(0);
				sclk = 0;
void write_adc1()
			int i;
			for(i=0;i<8;i++)
					sdi = ACC^7;
					sclk = 1;
					sdelay(0);
					sclk = 0;
					ACC = ACC << 1;
	void write_adc()
			cs1 = 1;
			sclk = 1;
			sdelay(0);
			cs1 = 0;
			sdelay(0);
			sclk = 0;
			ACC = command;
			write_adc1();
			ACC = adc24;
			write_adc1();
			ACC = adc16;
			write_adc1();
			ACC = adc8;
			write_adc1();
			sdi = 1;
			sdelay(0);
			cs1 = 1;
			sdelay(0);
	void initiate_adc()
			command = 0xff;
			adc24 = 0xff;
			adc16 = 0xff;
			adc8 = 0xfe;
			write_adc();
			command = 0x40;
			adc24 = 0x00;
			adc16 = 0x00;
			adc8 = 0x81;
			write_adc();
			command = 0x4a;
			adc24 = 0x00;
			adc16 = 0x03;
			adc8 = 0xe8;
			write_adc();
			command = 0x78;
			adc24 = 0x00;
			adc16 = 0x00;
			adc8 = 0x1e;
			write_adc();
			command = 0x40;
			adc24 = 0x00;
			adc16 = 0x00;
			adc8 = 0x71;
			write_adc();
			command = 0x74;
			adc24 = 0x00;
			adc16 = 0x00;
			adc8 = 0x00;
			write_adc();
			command = 0x5E;
			adc24 = 0xff;
			adc16 = 0xff;
			adc8 = 0xff;
			write_adc();
I have define all the variable...
I believe you did, but why no showing the complete code?
Also you didn't mention the ADC type, so we can't check if the SPI code is right for it.
Sorry its my mistake...
ADC is CS5460A i have used.
complete code is showing below...
Here you can see read & write routine of ADC is different then last one but i have keep old one also in this code.
old one is not working in present code, it is in sleeping mode right now...
#include <AT89X55.H>
#include <MATH.H>
//#include <lcd.h>
sfr lcd_data_pin=0xA0;  // data port P2
sbit rs=P3^7; // Register select pin
sbit rw=P3^6; // Read write pin
sbit en=P3^5; // Enable pin
sbit power_hz=P1^0;  // Frequency Count
sbit cs1=P1^1;		 // Chip Select Pin for ADC
sbit sdo=P1^4;		 // SDO pin for ADC
sbit sclk=P1^5;		 // SCLK pin for ADC
sbit sdi=P1^6;		 // SDI pin for ADC
sbit lsb=ACC^0;
	char bdata swich;
	sbit enter = swich^0;
	sbit right = swich^1;
	sbit up = swich^2;
	sbit set = swich^3;
	volatile long a,c,rpm_count,rpm,frequency;
	volatile char page_count,lo_count,pulse_ov,pulse_count;
	volatile char rotate_cur,adc24,adc16,adc8,command;
	volatile char eprom,eprom8,eprom16,eprom24,eprom32;
	unsigned long d;
	unsigned char d1,d2,d3,d4,d5,d6,d7,d8;
void dis_2();
void dis_3();
void dis_kgm();
void dis_po();
void dis_crpm();
void dis_freq();
void jump();
void write_adc1();
void write_adc(const unsigned char);
void read_adc(const unsigned char);
	void delay(unsigned int msec)    //delay function
			int i,j;
			for(i=0;i<msec;i++)
			for(j=0;j<1275;j++);
	void sdelay(unsigned int msec)    //delay function
			int i,j;
			for(i=0;i<msec;i++)
			for(j=0;j<1;j++);
	void lcd_command(unsigned char comm) // function to send command to LCD
			lcd_data_pin=comm;
			en=1;
			rs=0;
			rw=0;
			delay(1);
			en=0;
	void lcd_data(unsigned char disp)    // function to send data on LCD
			lcd_data_pin=disp;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
	lcd_dataa(unsigned char *disp)    // function to send string to LCD
			int x;
			for(x=0;disp[x]!=0;x++)
					lcd_data(disp[x]);
	void lcd_ini()     //Function to inisialize the LCD
			lcd_command(0x38);
			delay(5);
			lcd_command(0x0C);
			delay(5);
//	void _16_add()
//			unsigned int c,d;
//			unsigned char a=0xFF,b=0xFF,d1,d2,d3,d4,d5;
//			c = 0x01;
//			d = c/10;
//			d1 = c%10;		// LSB
//			c = d/10;
//			d2 = d%10;		// LSB-1
//			d = c/10;
//			d3 = c%10;		// LSB-2
//			c = d/10;
//			d4 = d%10;		// MSB+1
//			d5 = d/10;		// MSB
//			d1 = d1+0x30;
//			d2 = d2+0x30;
//			d3 = d3+0x30;
//			d4 = d4+0x30;
//			d5 = d5+0x30;
//			lcd_command(0x0C);
//			delay(5);
//			lcd_command(0x80);
//			delay(5);
//			lcd_data_pin=d5;
//			en=1;
//			rs=1;
//			rw=0;
//			delay(1);
//			en=0;
//			lcd_data_pin=d4;
//			en=1;
//			rs=1;
//			rw=0;
//			delay(1);
//			en=0;
//			lcd_data_pin=d3;
//			en=1;
//			rs=1;
//			rw=0;
//			delay(1);
//			en=0;
//			lcd_data_pin=d2;
//			en=1;
//			rs=1;
//			rw=0;
//			delay(1);
//			en=0;
//			lcd_data_pin=d1;
//			en=1;
//			rs=1;
//			rw=0;
//			delay(1);
//			en=0;
	void hz()
			TH2 = 0x00;
			TL2 = 0x00;
				while(power_hz == 0)
				while(power_hz == 1)
			TR2 = 1;
//				while(power_hz == 0)
//				while(power_hz == 1)
			TR2 = 0;
		void bitsep16()
			d = c/10;
			d1 = c%10;		// LSB
			c = d/10;
			d2 = d%10;		// LSB-1
			d = c/10;
			d3 = c%10;		// LSB-2
			c = d/10;
			d4 = d%10;		// MSB+1
			d = c/10;
			d5 = c%10;		// MSB
			c = d/10;
			d6 = d%10;		// MSB+1
			d = c/10;
			d7 = c%10;
			d8 = c%10;
			d1 = d1+0x30;
			d2 = d2+0x30;
			d3 = d3+0x30;
			d4 = d4+0x30;
			d5 = d5+0x30;
			d6 = d6+0x30;
			d7 = d7+0x30;
			d8 = d8+0x30;
		void lcd()
		//	c = a;
			c = rpm;
			bitsep16();
			lcd_command(0xC0);
			delay(5);
			lcd_data_pin=d8;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d7;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d6;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d5;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d4;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d3;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d2;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d1;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			c = frequency;
			bitsep16();
			lcd_data_pin=0x46;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x3a;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d4;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d3;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x2E;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d2;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d1;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
	void dis_pole()
			lcd_command(0x80);
			delay(5);
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x45;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x4E;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x54;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x45;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x52;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x50;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x4F;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x4C;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x45;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_command(0xC0);
			delay(5);
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20; // ahiya pole data move karavo
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
	void dis_cal()
			lcd_command(0x80);
			delay(5);
			lcd_data_pin=0x57;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x41;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x4E;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x54;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x43;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x41;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x4c;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x49;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x42;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x52;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x41;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x54;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x49;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x4F;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x4E;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_command(0xC0);
			delay(5);
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
	void dis_psw()
			lcd_command(0x80);
			delay(5);
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='E';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='N';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='T';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='E';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='R';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='P';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='A';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='S';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='S';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='W';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='O';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='R';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='D';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_command(0xC0);
			delay(5);
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
	void dis_al()
			lcd_command(0x80);
			delay(5);
			lcd_data_pin='E';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='N';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='T';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='E';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='R';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='A';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='R';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='M';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='L';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='E';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='N';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='G';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='T';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='H';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_command(0xC0);
			delay(5);
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
	void dis_kg()
			lcd_command(0x80);
			delay(5);
			lcd_data_pin='E';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='N';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='T';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='E';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='R';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='S';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='T';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='D';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='W';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='E';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='I';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='G';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='H';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin='T';
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_command(0xC0);
			delay(5);
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
	void increment()
	void enter1()
	void rotate()
	void ISR_Extern0(void) interrupt 0
			swich = P0;
			swich = ~swich;
			EX0 = 0;
	void key_press()
			if(swich != 0)
					if(set == 1)
				mode:		swich = 0;
							lo_count = lo_count+1;
							if(lo_count == 1)
									rotate_cur = 0x00;
									dis_pole();
				pole:				EX0 = 1;
									while(INT0 == 1)
									while(INT0 == 0)
									if(set == 1)
											goto mode;
									if(up == 1)
											increment();
									if(enter == 1)
											enter1();
									goto pole;
							else if(lo_count == 2)
									dis_cal();
				cal:				EX0 = 1;
									while(INT0 == 1)
									while(INT0 == 0)
									if(set == 1)
											goto mode; // ahiya mode ni jagya e out kari ne out nu routine call karavanu rehase.
									if(enter == 1)
											enter1();
									goto cal;
							else if(lo_count == 3)
									rotate_cur = 0x00;
									dis_psw();
				psw:				EX0 = 1;
									while(INT0 == 1)
									while(INT0 == 0)
									if(set == 1)
											goto mode;
									if(up == 1)
											increment();
									if(right == 1)
											rotate();
									if(enter == 1)
											enter1();
									goto psw;
							else if(lo_count == 4)
									rotate_cur = 0x00;
									dis_al();
				al:					EX0 = 1;
									while(INT0 == 1)
									while(INT0 == 0)
									if(set == 1)
											goto mode;
									if(up == 1)
											increment();
									if(right == 1)
											rotate();
									if(enter == 1)
											enter1();
									goto al;
							else if(lo_count == 5)
									rotate_cur = 0x00;
									dis_kg();
				kg:					EX0 = 1;
									while(INT0 == 1)
									while(INT0 == 0)
									if(set == 1)
											goto mode;
									if(up == 1)
											increment();
									if(right == 1)
											rotate();
									if(enter == 1)
											enter1();
									goto kg;
							else
									lo_count = 0;
									IT0 = 1;
									IE0 = 1;
									EX0 = 1;
									EA = 1;
									goto up;
					else if(up == 1)
							EX0 = 0;
							up = 0;
							page_count = page_count+1;
					up:			if(page_count == 1)
										dis_2();
										return;
								else
										page_count = 0;
										dis_3();
										return;
					else if(right == 1)
							lcd_command(0xC0);
							delay(5);
							lcd_data_pin=0x43;
							en=1;
							rs=1;
							rw=0;
							delay(1);
							en=0;
					else if(enter == 1)
							enter = 0;
							while (P0_0 == 0)
							while (P0_0 == 1)
								EX0 = 1;
								if(up == 1)
										EX0 = 0;
										up = 0;
										if(page_count == 1)
												dis_2();
										else
												page_count = 0;
												dis_3();
							while (P0_0 == 0)
								enter = 0;
					else
							IT0 = 1;
							IE0 = 1;
							EX0 = 1;
							EA = 1;
			else
						IT0 = 1;
						IE0 = 1;
						EX0 = 1;
						EA = 1;
	void dis_3()
			dis_kgm();
			dis_po();
			return;
	void dis_2()
			dis_crpm();
			dis_freq();
			return;
	void dis_kgm()
			lcd_command(0x80);
			delay(5);
			lcd_data_pin=0x54;			//1
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x3a;			//2
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d4;			//3
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d3;			//4
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x2E;			//5
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d2;			//6
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d1;			//7
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;			//8
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
// start RPM display
			lcd_data_pin=0x52;			//9
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x3a;			//10
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d4;			//11
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d3;			//12
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d2;			//13
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d1;			//14
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;			//15
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
// start pole display
			lcd_data_pin=0x20;			//16
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
	void dis_po()
			lcd_command(0xC0);
			delay(5);
			lcd_data_pin=0x50;			//1
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
// start Slip display
			lcd_data_pin=0x53;			//9
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x2E;			//13
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d2;			//14
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d1;			//15
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
//	start Hold Display
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
	void dis_crpm()
			lcd_command(0x80);
			delay(5);
			lcd_data_pin=0x43;			//1
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d2;			//5
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=d1;			//6
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			lcd_data_pin=0x20;			//7
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
	void dis_freq()
			c = frequency;
			bitsep16();
			lcd_command(0xC0);
			delay(5);
			lcd_data_pin=0x46;			//1
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
			en=1;
			rs=1;
			rw=0;
			delay(1);
			en=0;
	void ISR_Timer0(void) interrupt 1
			TF0 = 0x00;
			pulse_count = pulse_count+1;
			if (pulse_count == 1)
					TH1 = 0x00;
					TL1 = 0X00;
					TR1 = 1;
			else
					TR1 = 0;
					TR0 = 0;
					pulse_count = 0;
					pulse_ov = 0;
	void ISR_Timer1(void) interrupt 3
			TF1 = 0;
			pulse_ov = pulse_ov+1;
			return;
	void rpm_start()
			ET1 = 1;
			ET0 = 1;
			EA  = 1;
			TR0 = 1;
//	void write_adc1()
//			int i;
//			for(i=0;i<8;i++)
//					sdi = ACC^7;
//					sclk = 1;
			//		sdelay(1);
//					sclk = 0;
//					ACC = ACC << 1;
//			return;
//	void write_adc()
//			cs1 = 1;
//			sclk = 1;
	//		sdelay(1);
//			cs1 = 0;
	//		sdelay(3);
//			sclk = 0;
//			ACC = command;
//			write_adc1();
//			ACC = adc24;
//			write_adc1();
//			ACC = adc16;
//			write_adc1();
//			ACC = adc8;
//			write_adc1();
//			sdi = 1;
	//		sdelay(2);
//			cs1 = 1;
	//		sdelay(2);
//			return;
	void write_adc(const unsigned char regAddr)
		unsigned char SPICount;
  		unsigned char SPIData;
  		cs1 = 1;
  		sclk = 0;
  		SPIData = 0x40;
  		cs1 = 0;
		for (SPICount = 0; SPICount < 8; SPICount++)
    			if (SPIData & 0x80)
      				sdi = 1;
    			else
      				sdi = 0;
    				sclk = 1;
    				sclk = 0;
    				SPIData <<= 1;
  		cs1 = 1;
  		sdi = 0;
	void initiate_adc()
	//		command = 0xff;
	//		adc24 = 0xff;
	//		adc16 = 0xff;
	//		adc8 = 0xfe;
			write_adc(0xff);
			write_adc(0xff);
			write_adc(0xff);
			write_adc(0xfe);
	//		command = 0x40;
	//		adc24 = 0x00;
	//		adc16 = 0x00;
	//		adc8 = 0x81;
			write_adc(0x40);
			write_adc(0x00);
			write_adc(0x00);
			write_adc(0x81);
	//		command = 0x4a;
	//		adc24 = 0x00;
	//		adc16 = 0x0f;
	//		adc8 = 0xa0;
	//		command = 0x78;
	//		adc24 = 0x00;
	//		adc16 = 0x00;
	//		adc8 = 0x1e;
			write_adc(0x78);
			write_adc(0x00);
			write_adc(0x00);
			write_adc(0x1e);
	/*		command = 0x40;
			adc24 = 0x00;
			adc16 = 0x00;
			adc8 = 0x71;
			write_adc();   */
			write_adc(0x40);
			write_adc(0x00);
			write_adc(0x00);
			write_adc(0x71);
	/*		command = 0x74;
			adc24 = 0x00;
			adc16 = 0x00;
			adc8 = 0x00;
			write_adc();   */
			write_adc(0x74);
			write_adc(0x00);
			write_adc(0x00);
			write_adc(0x00);
	/*		command = 0x5E;
			adc24 = 0xff;
			adc16 = 0xff;
			adc8 = 0xff;
			write_adc();   */
			write_adc(0x5e);
			write_adc(0xff);
			write_adc(0xff);
			write_adc(0xff);
			write_adc(0x4a);
			write_adc(0x00);
			write_adc(0x03);
			write_adc(0xe8);
			return;
/*	void read_adc1()
			int i;
			ACC = 0x00;
			for(i=0;i<7;i++)
				lsb = sdo;
				ACC = ACC << 1;
				sclk = 1;
		//		sdelay(1);
				sclk = 0;
				lsb = sdo;
				ACC = ACC << 1;
				sdi = 0;
				sclk = 1;
		//		sdelay(1);
				sclk = 0;
				return;
/*	void read_adc()
	//		sclk = 1;
			cs1 = 1;
	//		sdelay(1);
			cs1 = 0;
	//		sdelay(3);
			sclk = 0;
			write_adc(0x0A);
			sdi = 1;
			read_adc1();
			adc24 = ACC;
			sdi = 1;
			read_adc1();
			adc16 = ACC;
			sdi = 1;
			read_adc1();
			adc8 = ACC;
			sdi = 1;
	//		sdelay(2);
			cs1 = 1;
	//		sdelay(2);
			return;
	void read_adc(const unsigned char regAddr)
  			cs1 = 1;
  			sclk = 0;
  			SPIData = regAddr;
			cs1 = 0;
    					if (SPIData & 0x80)
      						sdi = 1;
    					else
      						sdi = 0;
    						sclk = 1;
    						sclk = 0;
    						SPIData <<= 1;
  			sdi = 1;
			ACC = 0;
  				for (SPICount = 0; SPICount < 7; SPICount++)
						lsb = sdo;
    					sclk = 1;
						ACC <<= 1;
    					sclk = 0;
						lsb = sdo;
    			//		ACC <<= 1;
						sdi = 0;
    					sclk = 1;
    					sclk = 0;
						sdi = 1;
				adc24 = ACC;
		//	sdi = 1;
			ACC = 0;
						lsb = sdo;
    					ACC <<= 1;
    					sclk = 1;
    					sclk = 0;
						lsb = sdo;
    			//		ACC <<= 1;
						sdi = 0;
    					sclk = 1;
    					sclk = 0;
						sdi = 1;
				adc16 = ACC;
		//	sdi = 1;
			ACC = 0;
						lsb = sdo;
    					ACC <<= 1;
    					sclk = 1;
    					sclk = 0;
						lsb = sdo;
    			//		ACC <<= 1;
						sdi = 0;
    					sclk = 1;
    					sclk = 0;
						sdi = 1;
				adc8 = ACC;
		//		sdi = 1;
  				cs1 = 1;
		  return;
	void cycle_count()
			read_adc(0x0a);
			rpm = (65536 * adc24) + (256 * adc16) + adc8;
			frequency = 0x3e8;
			return;
	void main()
			lcd_ini();
	//		TMOD = 0x16;
	//		T2CON = 0x01;
	//		lcd_welcome();
	//		delay(300);
	//		IT0 = 1;
	//		IE0 = 1;
	//		EX0 = 1;
	//		TH0 = 0xff;
	//		EA = 1;
			lcd_command(0x01);
			delay(5);
		//	dis_3();
			initiate_adc();
			while(1)
		//	hz();
		//	rpm_start();
			cycle_count();
		//	key_press();
		//	EX0 = 1;
		//	dis_3();
			lcd();
