RatedR
Junior Member level 1
- Joined
- Jul 13, 2017
- Messages
- 17
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 151
I have already made those two ppe . The one using upper and lower mask two priority encoder and a mux..One using decoder , n priority encoder and mux...I also read somewhere about a ppe using rotate + priority encoder+adder....But unable to remember it since I have lost that page...And consequently unable to do it...The problem is that my teacher is saying to bring a solution which isn't already given in book...I have also made the barrel shifter + priority encoder + barrel shifter method...But it is also provided somewhere...But I haven't seen this thing " There is also a version that does the masks and then determines which mask would be best and then has a mux on the input." I just can't think of any new logic . I am struck in the logic itself that's the reason I can't post any progress or code as I can do them by myself once the logic is figured..If you can help me in figuring out a new logic that would be really helpful.. thanks
ah, ok. I see what the project was.
I think this project was to show this masking idea. I hadn't seen it before but it makes sense.
There are four ppe's that could be compared. There is the one from the book -- that has two mask and two priority encoders and a mux on the output. There is also a version that has N priority encoders and an output mux. There is also this barrel shifter version that allows a single encoder. There is also a version that does the masks and then determines which mask would be best and then has a mux on the input. Because the book mentions two options -- the one that is depicted with a diagram and a version that has N priority encoders and a mux -- I suggest you focus on these two. This will let you post the results and conclusions reached in the book.
