Orson Cart
Advanced Member level 3
- Joined
- Jun 18, 2009
- Messages
- 798
- Helped
- 347
- Reputation
- 1,146
- Reaction score
- 558
- Trophy points
- 1,373
- Location
- New Zealand
- Activity points
- 5,973
IR2117 looks OK.
VBSD1-S15-S15-SIP 15V to 15V 1kV isolation looks OK but has a min load requirement on the ouput,so you will need a 1watt 16V zener on its o/p to keep the volts below 16.
Yes, you can use the IR2110, but if you have 8 fets on each side you will need 7 IR2110's for each side as you can only use the low side part for the 0V connected fets. you can only use the high side part for the 7 upper fets.
Regards, Orson Cart.
