toyonline
Hi, I have made a tuned circuit for voltage amplification purpose. The LC circuit was attached. Basically, the circuit has two resonance frequency of ~750kHz and ~1.5MHz. According to Spice simulation, voltage gain at node(005) was the same at the two frequencies. And in practice, the circuit works, and voltages at two frequencies are roughly the same to each other. I used the circuit for several months.
But here comes the problem. Recently, a voltage gain at 1.5MHz reduces to only half of previous value. That is, voltage gain at 750kHz is twice as at 1.5MHz. So, I want to find out the reason for this phenomenon and fix the circuit. But I just cannot see any obvious reason for such a voltage decreasing.
I would be appreciated if anyone give me some suggestions on my problem.
Thank you.
Thank you.
