kkeeley
Member level 3
Thanks DXNewcastle for your support and ideas,
I'm not sure at this point what I can do with the transformer in the way of repairing it, I might be able to carefully remove the outside layers of tape and see if I can access the end of the damaged wire. At this time I'm going to hold off and wait and see what if any suggestion come along as to what to do. I don't which to damage or change the characteristics of the transformer as this may make matters worst.
I have got access to some old PC power supplys, so I will try to find one that uses the same style circuit and look to get the transformer out of that. The only problem may be that the setup of the transformer could be different which in turn will mean I have to redesign the circuit to work with the new transformer.
If I can get help on how to obtain all the information I need on the exisiting transformer, either by calculations or by the carefull disassembling of the transformer I might have a go at rebuilding it. I need to find out more about how to build my own trnasformers first though. Is it really that hard if you have the information you need?
Thanks for your help againg.
Kenneth
Kenneth
