OK.Often one web site copies images from another and the mistake is repeated. As far as I can tell, the IR2153 is a standard bootstrapped totem-pole driver so both MOSFETs should be of the same type. The top one OR the bottom one should be turned on (with dead time) but not both at the same time. Inverting one and using a P-channel device, if it worked at all, would turn them on at the same time.
This is the schematic of a plasma generator named PVM500 that it's manufactory plain in the website for customers to download & instructions. and i'm want to test it.Where did you find these schematics?
