Problem with LCD implementation on Proteus
Hello everyone. I currently work on a small project to evaluate air quality using MQ135 sensor with Atmega16. The simulation works fine for me, but there is a problem with LCD representation in the Proteus simulator. As I want the LCD to display the air quality based on the PPM, the GOOD one sounds fine, but the AVG and BAD have an extra D at the back, which become BADD and AVGD. Does anyone know how to solve this problem or is this an error from Proteus ?
Below is my code written on IDE CodeVisionAVR :
#include <mega16.h>
#include <string.h>
#include <math.h>
#include <stdio.h>
#include <delay.h>
// Alphanumeric LCD functions
#include <alcd.h>  //chen thu vien lcd
// Declare your global variables here
// Voltage Reference: AREF pin
#define ADC_VREF_TYPE ((0<<REFS1) | (0<<REFS0) | (0<<ADLAR))
// Read the AD conversion result
unsigned int read_adc(unsigned char adc_input)//doc gia tri adc
    ADMUX=adc_input | ADC_VREF_TYPE;
    // Delay needed for the stabilization of the ADC input voltage
    delay_us(10);
    // Start the AD conversion
    ADCSRA|=(1<<ADSC);
    // Wait for the AD conversion to complete
    while ((ADCSRA & (1<<ADIF))==0);
    ADCSRA|=(1<<ADIF);
    return ADCW;
void main(void)
unsigned int gas;
char arr[15];
// ADC initialization
// ADC Clock frequency: 125.000 kHz
// ADC Voltage Reference: AREF pin
// ADC Auto Trigger Source: Free Running
ADMUX=ADC_VREF_TYPE;
ADCSRA=(1<<ADEN) | (0<<ADSC) | (1<<ADATE) | (0<<ADIF) | (0<<ADIE) | (1<<ADPS2) | (1<<ADPS1) | (0<<ADPS0);
SFIOR=(0<<ADTS2) | (0<<ADTS1) | (0<<ADTS0);
lcd_init(16); //khoi dong lcd
DDRA.0 = 0;
while (1)
      // Place your code here
         gas = read_adc(0);//du lieu gas
         sprintf(arr,"Gas:%02d PPM",gas);
         PORTD.4=1;
         lcd_gotoxy(0,1);
         lcd_puts(arr);
      if(gas>=0 && gas<=600)
      // Purple light for good
      PORTD.5 = 1;
      PORTD.4 = 0;
      PORTD.6 = 0;
      lcd_gotoxy(0,0);
      lcd_puts("GOOD");
      else if (gas>600 && gas<=800)
      // Yellow for average
      PORTD.6 = 1;
      PORTD.5 = 0;
      PORTD.4 = 0;
      lcd_gotoxy(0,0);
      lcd_puts("AVG");
      else {
      // Red for bad
      PORTD.4= 1;
      PORTD.5 = 0;
      PORTD.6 = 0;
      lcd_gotoxy(0,0);
      lcd_puts("BAD");
And the image of 2 cases I mention already been attached.
"GOOD" has 4 characters.
"BAD" has only 3. Thus if you don't delete the 4th character of "GOOD" = "D" in the display it will remain there.
Why not simply defining "BAD " = also as 4 character text?
Klaus
Thank you for your solution. In fact I just put a space by the end of the character statement for "BAD" and "AVG" and it works perfectly
