[SOLVED] problem with layout of resistance and capacitor
You cant connect M1 directly to M5 or M6, you need to make a via stack, in other words: Connect M1 to M2, M2 to M3, M3 to M4, M4 to M5. This is the only way to make a connection between M1 and M5.
i found those contacts to be via5.....
as u say will it connect to metal 1 i tried the connections are not working????
---------- Post added at 15:36 ---------- Previous post was at 15:36 ----------
sorry its vi5....say now its vi 5 how do i connect it to say poly or metal??
---------- Post added at 15:43 ---------- Previous post was at 15:36 ----------
vias are usually used in contacts can u let me know in which documents to look to find out what two layers VI5 will connect (i am assuming VI5 is a via)
also can you let me know will ne documents let me know how to connect these instances and how they perform.thn i can ask the vendor to provide us with them!!!
This is a mimcap, MiM stands for metal-insulator-metal so no poly is involved nor present in the layout
Since you see via5 this should suggest you that metal5 and metal6 are involved.
Anyway I had a look use metal 6 for the top plate and metal5 or 6 for the bottom plate
top[ plate as in layout.....
might sound silly but i am a bit confused
c when the layout appears the two column terminal is on the top of the screen and the multi column terminal at the bottom ...but if i think of the layers as one over anather....look at as if its been flattened in one dimention it appears the multi layer terminal is on a metal layer on top of anathermetal layer...that thinking makes it the top layer
so which one is the top layer...
shud i look at it in two dimensions or imagine it in three dimension??
