Problem with" if Condition" in C language
Question about if condition in" C" language
Hi guys,
Can we call a function in condition of if in another function?
for example
MemRead1 is first function,TX_byte is second
unsigned int MemRead1(unsigned char SlaveAddress,unsigned char command1)
  //some statements
if(TX_byte(SlaveAddress)){
do sth;
do sth
I hope ,I had a good explanation of my question.
Thanks in advance.;-)
Re: Question about if condition in" C" language
are you talking about
If TX_byte(SlaveAddress) returns some value like 0 or 1 and if the value is 1 i.e., true then the if condition is executed.
Yes you can call a second function within the first function. Make sure the second function to be called is written above the first function. Or make sure that you've declared the functions at the beginning of your code.
I have declared function at the beginning of codes but i think second function doesn't return any thing.
By "doesn't return any thing", do you mean that you get a zero as the result? Or that it's not a function, but a procedure?
I did not get result in simulation,so I test program by toggle a pin of port
like this :
if (TX_byte(Slaveaddress)){
PORTD.0=~PORTD.0;
goto repeat;
but i didn't see any thing in oscilloscope of Proteus
unsigned char Tx_byte(unsigned char Tx_buffer)
 unsigned char Bit_counter;
unsigned char Ack_bit;
unsigned char bit_out;
for(Bit_counter=8;Bit_counter>=1;Bit_counter--)
if(Tx_buffer&0x80==1)
bit_out=1;
else
bit_out=0;
send_bit(bit_out);
Tx_buffer<<=1;
Ack_bit=Receive_bit();
return Ack_bit;
SlaveAddress=0x5A;send_bit(),Receive_bit() are function
Hi fizo741,
the condition
will be always false. I guess that what you meant is
if(Tx_buffer&0x80==0x80)
or simply
if(Tx_buffer&0x80)
Regards
Z
Hi my friends,
Thanks for your guides,
actually it is an example program i want to use,in TX_byte() function i want to send one time SlaveAddress,SlaveAddress is 8 bit as i said before 0x5A, and Msb should send first and then other bits.It is like sending 8 bits one by one.
I've corrected my program,but again i do not see any thing in oscilloscope at proteus.
when i debuged, i had this error:
[coff]Could not load source file!
I do not know why?!Do you have any idea:idea:
Do you think it's because of goto:?:
You can "dry run" the code.
What are the functions send_bit() and Receive_bit() ? Are they library functions? If so, what do they do? If no, then can you post the code for these functions?
