Problem of simulation of BSIM4 model
Yassir_eldo
Junior Member level 2
Hello everybody,
I am trying to simulate a CMOS inverter with transient analysis using BSIM4 Berkley Model in ELDO, but the simulation result that I found is a Follower (nearly the same curve than the input). Could anybody tell me why I have this problem with BSIM4v4? I have tried BSIM3v3, some TSMC models, BSIMSOI and I have all the time the inversion result. U find enclosed the schematic that I use.
Best regards
Could you pls. show the netlist which you used for the BSIM4v4 simulation?
Here is my nitlist: the .cir file. U find enclose a screenshot of the simulation result that I have obtain
* Component: $Projet_0/default.group/logic.views/cell_1 Viewpoint: eldonet
.INCLUDE $Projet_0/default.group/logic.views/cell_1/eldonet/cell_1_eldonet.spi
.INCLUDE /home/elbarki/Desktop/models/BSIM4.pmos
.INCLUDE /home/elbarki/Desktop/models/BSIM4nmos
.OPTION NOASCII
.OPTION MODWL
.OPTION ENGNOT
.OPTION AEX
* --- Singles
* - Analysis Setup - Trans
.TRAN 0 150n 0
* --- Waveform Outputs
.PLOT TRAN V(A) V(B)
* --- Forces
VFORCE__A A GROUND PULSE (0 5v 0 0.5e-09 0.5e-09 5e-08 1e-07)
VFORCE___VDD VDD GROUND dc 5v
* --- Libsetup
.OPTION NOASCII
.OPTION MODWL
.OPTION ENGNOT
.OPTION AEX
* --- Singles
.TRAN 0 150n 0
* --- Forces
* --- Libsetup
No, sorry, I thought of your circuit netlist file, which contains the circuit of your inverter, probably this one:
The (possible) reason: Until BSIM3v3, source & drain of a MOSFET are exchangeable, so the order (D G S B) & (S G D B) were equivalent. If this should have changed with BSIM4 (I really don't know, but layout-dependent reasons could render this necessary), your inverter circuit actually could be a (non-inverting) complementary source follower, if your netlist contains the order (S G D B). Also, the low output voltage of only 4V indicates this.
You could try and falsify or verify this assumption, if you exchange the S & D positions @ both transistors in the netlist (s. above). Then re-simulate (without prior re-netlisting, of course).
