[SOLVED] problem in reading multiple adc channels
short is 1 byte. Long is 4 bytes. So, you can have values upto 65535, but takes more memory.
If mikroC tells not enough ram/rom, then switch to PIC16F877 or PIC16F877A.
Can you send me the file picsimulatoride.exe?
find attachment...
  • picsimulatoridesetup691.rar
going nice.... just experimenting in bread boards....
but there is a problem in batfullled... its taking high value always...
it should be 'ON' only when bsvalue > hbat ....
check the code once...
#include<htc.h>
#include<stdlib.h>
#include<stdio.h>
__CONFIG(FOSC_INTRCCLK&PWRTE_ON&BOREN_OFF&WDTE_OFF);
//Solar Charge Controller
#define batfullled PORTAbits.RA4
#define batlowled PORTAbits.RA0
#define solarsense PORTCbits.RC2
#define spulse PORTAbits.RA5
#define olsense PORTCbits.RC3
#define load PORTAbits.RA2
#define solarled PORTCbits.RC4
#define batsense PORTCbits.RC1
#define tempsense PORTCbits.RC0
// Prototypes
void Delay_ms(unsigned int);
unsigned short int adc(unsigned char source);
// Subroutines
void Delay_ms(unsigned int time)
			unsigned int i,j;
			for(i = 0 ; i < time ; i++);
			for(j = 0; j < 165 ; j++);
        unsigned short int result = 0;// 16/32 bit variable to hold the 10 bit A/D result
        ADRESL = 0x00;
        ADRESH = 0x00;
        switch(source)
                case 'o':
                        ADCON0=0x9C;
                        break;
                case 's':
                        ADCON0=0x98;
                        break;
                case 'b':
                        ADCON0=0x94;
                        break;
                case 't':
                        ADCON0=0xD0;
                     	break;
				Delay_ms(5);
				ADCON0bits.ADON = 1;
                Delay_ms(1);
                ADCON0bits.GO = 1;
                while(ADCON0bits.GO);
                ADCON0bits.ADON = 0;
                result = ADRESH;        // copy high byte to result
                result <<= 8;           // shift low byte to 2nd byte
                result |= ADRESL;       // OR result with ADRESL to get both the bytes into one var.
                Delay_ms(5);
                return result;          // return the value in result
void main(void)
	unsigned short int ssvalue,olvalue;
    unsigned short int bsvalue,tsvalue;
    unsigned short int lon_value = 195;              //(for 4V)
    unsigned short int htvalue = 819;                //(for 17V)
    unsigned short int ltvalue = 195;                //(for 4V)
    unsigned short int olvoltage = 819;              //(for 17V)
    unsigned short int hbat = 707;                   //(for 14.5V)
    unsigned short int lbat = 532;                   //(for 11V)
    unsigned short int htemp = 200; //196            //(for 49 C)
	unsigned short int bivoltage = 584;              //(for 12V)
	TRISAbits.TRISA0 = 0;          //bat low led
    TRISAbits.TRISA4 = 0;          //bat full led
    TRISCbits.TRISC2 = 1;          //solar sense
    TRISAbits.TRISA5 = 0;          //spulse
    TRISCbits.TRISC3 = 1;          //ol sense
    TRISAbits.TRISA2 = 0;          //load
    TRISCbits.TRISC4 = 0;          //solarled
    TRISCbits.TRISC0 = 1;          //temp sense
    TRISCbits.TRISC1 = 1;          //bat sense
    ANSEL = 0xF0;              // analog channel i/p o/p config
    // Fosc = 4 Mhz, Tosc = 1/Fosc = 0.25us = 250ns
    // Tad = 16 * Tosc = 4us
    // min Tad = 1.6us
    // ADCS2-ADCS0 = 101
    // ADCON1 = 01010000 or 0x50
    ADCON1 = 0x50;     // select conversion clock
    CMCON = 0x07;      //comparator off
    solarled = 1;      //led ON to show uc working
	while(1)
				Delay_ms(1);
                ssvalue = adc('s');
				Delay_ms(1);
                olvalue = adc('o');
				Delay_ms(1);
                bsvalue = adc('b');
				Delay_ms(1);
                tsvalue = adc('t');
				ADCON0bits.VCFG = 0;
				if ((ssvalue >= ltvalue) && (ssvalue <= htvalue) && (bsvalue <= hbat) && (tsvalue <= htemp) && (olvalue <= olvoltage))
    					Delay_ms(1000);
						Delay_ms(1000);
							spulse = 1;
                        	//charging = 1;
							//batlowled = 1;
                else if ((bsvalue >= hbat) || (tsvalue >= htemp) || (olvalue >= olvoltage))
                    Delay_ms(1000);
					Delay_ms(1000);
						spulse = 0;
                else
                {       spulse = 0;
                        //charging = 0;
						//batlowled = 0;
   				if(bsvalue >= bivoltage)
		   			goto loadon;
                else if((bsvalue <= bivoltage) && (load == 1))
					goto loadon;
         	    else if ((ssvalue >= lon_value) || (olvalue >= olvoltage) || (bsvalue <= lbat) || (tsvalue >= htemp))
					Delay_ms(1000);
					Delay_ms(1000);
						load = 0;
                goto jump;
    loadon:		if ((ssvalue <= lon_value) && (olvalue <= olvoltage) && (bsvalue >= lbat) && (tsvalue <= htemp))
					Delay_ms(1000);
					Delay_ms(1000);
						load = 1;
             		Delay_ms(1000);
					Delay_ms(1000);
					load = 0;
      jump:     if (bsvalue >= hbat)
                    //Delay_ms(1000);
					//Delay_ms(1000);
					//if (bsvalue >= hbat)
						batfullled = 1;
                else if (bsvalue <= lbat)
					//Delay_ms(1000);
					//Delay_ms(1000);
					//if (bsvalue <= lbat)
					batlowled = 1;
                else
                     batfullled = 0;
                     batlowled = 0;
Just tell me which led has to switch ON/OFF and when. Just tell me the conditions for leds. Where is the charging led?
