problem creating pmos caracteristics using spice model LTSPICE
yefj
Hello, I have tried to implement the PMOS characteristics using the model shown in the link.
I have built the model as shown in the photo bellow.
Vs=1.8V
V_SG=Vs-Vg=1.8-Vg>|Vt| => 1.8-Vg>0.39
i did a sweep on Vg from 0 till 1.8 so VSG is smaller then 0.39 at some point ,but in reality get the same current on the plot bellow.
Where did i go wrong?
from the manual shown bellow:
VsPrkXvG5dwciMYLf_JHJ4GGlRh0eF3xl_AKaxzADCRKBfWboFsV3TJEQr2MGqif5WcGafPRR48K5mJeBxkCRYru-i-dLAjtigYjel1xi7er9YU86nYXVgXoMvT2WY73xGMo_qKMG0SQtl415PFz_7U
ACq0rdERGfMgSpOm3HnboemG_7NJDD61ZU0neJO3gx9nM1f_3Tw7MwLfyvyyMdNwojhilsp3PC7zbkfx6Edq-H22OzGVVjppD9IfoNk8zHEE27iJq7vP1TkK--YqKcvyi6GhUK-exAlAscXHgPgep7I
A couple of places:
For a P-MOSFET, both voltages must be negative going.
The current your simulation shows is through the substrate parasitic diode (note the direction of the diode arrow).
And if you want a set of characteristic curves, as shown in the reference manual, you need to sweep both voltage sources, as shown in the example below:
Generally you want the gate voltage to start the sweep at the MOSFETs Vgs(ths) (which is -3.2V for the transistor below).
