Pressure Sensor alarm with PIC16F877A to activate the bulb
I don't know the pressure I am measuring I am applying on the sensor a small air pump which I use normally when making PCBs, so as I don't know its pressure I just wanted to test if it is possible to change the pressure by applying that element then I can interface to the PIC for switching purposes.
the output I have is the same as the one I have when applying that pump;
Use a sensor which is giving more output than the 2100, whta is your pressure range? use 5010 instead of 2100 ( If your pressure limit is less than 10Kpa)
I want to design a sensor which when applied an Air compressor for example,on MPX2100 in a given limit it has to sense and activate some other components in the circuits like a bulb for example.
It is clear that this sensor will be applied on analogue input of a PIC;what will be the codes to use?
Thanks.
My pressure range is unknown I am using an air pressure (TECAX AP1500)which I normally use for PCB Making;it has low pressure.
Thanks.
