KlausST
Advanced Member level 7
the first to test:
* voltage (DC) across the mic. Try to adjust RMIC to see about half VCC ( if not already done)
then:
* CIN2 should be high audio quality. No electrolyte, no X7R, no Z5U best no ceramics at all. Best to use foil.
* add a cap in the range of 10nF in parallel to R4. Use X7R here. (i know it might increase the power up popp...)
* to get lower noise i´d go to 10k Ohms or less for R3, R4
* Cout2 .. best a foil capacitor.
Gain is about 30 (varying with mic impedance) with the 10MHz GBW it should be OK
What load did you connect?
Klaus
the first to test:
then:
Klaus
