[SOLVED] Powering up a fan (3 wire) using MOSFET LL110
the error shows about int8 something not defined,
and which headers file should i include other than
#include <pic18f4520>
You must include pre-processor. I thought you will be aware of that. I need more information.
1. Which controller are you using?
2. Which kind of display?
Post the code which you have. I will try to correct the file.
Im using PIC18F4520..
The display that i want is to have the temperature readings from the TC74 sensor to be displayed on the LCD screen. and to refresh the readings every 1 second.
  • temp.rar
It seems that you didn't configure the i2c.
You have to add #use i2c (master,sda=PIN_C4, scl=PIN_C3)
after header files(#include).
add the line
HTML:
Here is my schematic
updated.. the file is not sent yet
  • Schematic.pdf
If you have proteus, load this hex file and check whether it works for you.
i2C should connect to RC3 and RC4
But while connecting the lcd to uC in proteus. do as follows:
RS to uC A2
EN to uC A1
R/W to ground
LCD D0-D7 to uC B0 to B7
  • main.rar
