sohail_akram
Member level 2
ANY DIODE has 10 times ampare of normal rating, surge .
Thank you FvM. The fuse I’m using is normal 3A fuse. I'm not sure which datasheet is attach for the fuse because it don't status the manufacturer but can we assume as standard 3A fuse? Bellow is shown the I-t curves that you mention? I attached the waveform from other datasheet.F2 is basically loaded with the DC output current and acts as shown in fuse I-t-curves. You may consult datasheets for the specific fuse type used in your test.
Sorry, not so sure your explanation. Is it the F2 current 3A have to multiplied the RMS(1.414) value? What is the 1.5-1.6 number for? is voltage?F2 is loaded by the DC current multiplied with a waveform factor (RMS/rectified mean value) depending on transformer impedance and filter capacitor, 1.5 - 1.6 is a typical value for a C-loaded full wave rectifier.
What will happen if effective the diode load value and RMS current? Is it will cause the DC fuse wouldn't burst off at 3A?While a fuse (resistive element) is always loaded with the RMS current, the effective diode load is somewhere between rectified mean value and RMS current.
