Mazz
Advanced Member level 2
I think we can make a summary now:
-you're experienced.
-your block diagram is a simplified one, that's ok, you explained the noisy spectrum.
-you've tested each block with no issues and the full system as well.
-so you're sure that there is no oscillation. I would agree with Rich, but I trust in you when you're saying that many tests have been done. If oscillations would appear you should have seen them.
-you say that the only issue is related to different configuration of PLLs and it gives you not always an unacceptable SNR, but only in some cases slight degradation of SNR, like the classical rotation in the constallation diagram seen when there is too much phase noise added.
I suppose that there is a very laaaarge gain in this system, I'm supposing your issue comes from some intermodulation product between actual signal and some spur generated by PLLs. This is very intuitive, I've not done any calculation (yet).
Having a signal/noise/linearity budget will help to understand if my idea is correct, you can see if some spur can fall into your useful bandwidth.
Did you try slight different LO frequencies between TX and RX to understand if the issue is in TX or RX?
Did you try to replace these PLL with signal generators?
I would like to give some more help, but it is not easy as you're giving few info about this project (and I understand why).
Mazz
Mazz
