T
treez
...here's one at 200kHzever tried to build an effective broadcast antenna at 531kHz..?
https://en.wikipedia.org/wiki/Droitwich_Transmitting_Station
…Yes but common mode noise above 20MHz can occur in pulses, and those pulses can be at a frequency of 150khz or so….and then that common mode noise shows up on the Quasi-Peak plot at 150khz…….also, those common mode chokes will offer some attenutation at >20MHz….if only better than not having that common mode choke there and just having bare wires.I would like to relate this statement to the common mode choke pictured along with it. It has unlikely relevant common mode suppression above 10 or 20 MHz. If your device is able to radiate RFI, this kind of common mode choke will hardly hinder it.
The chokes shown are admittedly for lower frequencies…….but in the near field, even lower frequencies can couple to adjacent things and jump out of a PCB where not intended….so those chokes aren’t entirely great at lower frequencies.
The question is whether common mode chokes are needed when there is no wired earth conenction........and the fact is that they are.....as the post of #12 shows...thats from one of the worlds best SMPS companies in China......they didnt put those chokes in there by mistake.
Another point is the PI Expert Design software by Power.com…if you do a offline flyback design in it, (with no earth connection, only Live and neutral) , it always puts a large common mode choke at the input…and has done for at least the last decade....this is not a mistake.
I’ve seen mains connected LED drivers failing badly on common mode noise at around 150khZ…….when you remove their earth wire connection, you do not suddenly pass the conducted EMC scan.
