udhay_cit
Full Member level 6
I did solve this problem before some time by disable the LVP(Low Voltage Programming usually need for Boot loader), So please make sure your configuration word is set for HV programming (high voltage programming)
sure i'll try that too..I like the latest mikroC not the Version 8.1
The difference between the version is that In trial version you cannot configure all the configuration bits as those are available only in registered version.
I think using 10 leds with 220R is not a good idea, the pic has a maximum limit of ampere to taken out.
