PIC16F877 ADC EXAMPLES assembly
STUDY ABOUT THE FOUR REGISTERS RELATED TO ADC;
1> ADCON0
2>ADCON1
3>ADRESH
4>ADRESL
make sure to give the required delay before reading adc(capacitor charge time ) and what you are reading(if it is from battery one read will do the work else you have to read more and take the average of that
1> ADCON0
2>ADCON1
3>ADRESH
4>ADRESL
This is available in data sheet..
Then using a C compiler 'like HIGH TECH C' try 2 write a program...
I am sure u could do it....
yes thanks.. i've read it in the data sheet and somehow i understand the functions and operations. but im required in my project to use MPLAB-IDE and assembly code programming.
Using assembly, it's not a problem. If you know assembly, just follow the process of setting ADCON0 and ADCON1 as required meeting suitable timing requirements, and then read from ADRESH and ADRESL. Now the catch is if you can use assembly or not. If you can, then go ahead and start coding, we'll help when you get stuck. If you can't time to grab hold of some tutorials or more preferably a book to understand all the instructions. If you've used assembly somewhere earlier, you might be able to get hold of it directly from the datasheet, otherwise you need some more help.
Hope this helps.
Tahmid.
Re: pic adc sample code
it`s very strange! why do you add 48 (30h)??? of course if you are converting the number to ASCII in some poor way it can`t display float numbers! did you think that usart_write can convert numbers to float???
mmmmm
well, i can suggest something like this
void main() {
float volt,press,calc,adc_value;
char inter, deci;
ADCON1 = 0x80; // Configure analog inputs and Vref
TRISA = 0xFF; // PORTA is input
TRISB = 0x3F; // Pins RB7, RB6 are outputs
TRISD = 0; // PORTD is output
usart_init(2400);
do {
adc_value = Adc_Read(2); // Get results of AD conversion
press = adc_value*0.005;
inter = (int) press;
deci= (int) (press*10.0) - inter*10;
usart_write('V');
usart_write('O');
usart_write('L');
usart_write('T');
usart_write('=');
usart_write(inter | 0x30);
usart_write('.');
usart_write(deci | 0x30);
usart_write(13);
usart_write(10);
delay_ms(1000);
} while(1);
sir, i would just like to ask, how can i do it that the output has 2 or 3 decimal places?
