PIC Programmer and software with ckt diagram
nt picprog. exe
I think JDM programmer & IC-Prog is the best .
Reactions: J@ck
    J@ck
k149 24cxx
amr_electron said:
I think JDM programmer .... is the best .
JDM doesn't work with all RS232 ports, especially with laptops (if you can find a RS232 on a laptop !)
USB => RS232 adapters usually dont work with JDM
amr_electron said:
I think ...... IC-Prog is the best .
IC-proc has not been updated since 18 month. Impossible to program up-to-date PICs like 16F88 and so on. Bonny no more respond to Emails. IC-prog 1.05C has many bugs
:roll:
download picprog
ICProg 1.05 is buggy and bonny does not respond to e-mails......TRUE.
But if you are looking for a programmer.....I have posted it here:
h**p://
No need to look further. The same version with transistors replaced by a single IC is posted by fragrance in the link above.
It works in JDM mode on the buggy version also, programmes EEPROM also, works 10/10 times.
So why this hunt for programmers all the time....its a pain man and confuses you and others.
bimbla.
oshonsoft pickit
:roll:
so, what is the best (hardware/free software) to use ?
regards .
programator brenner 16f684
Try this variation.....and you will have to use ANY PROGRAMMER only once
Use the programmer only once, the first time, to program you PIC with a bootloader.
After that you will never need a programmer. Load the code through the bootloader. It is more convenient and fast.
If more people are interested, I will detail this procedure if required.
bimbla.
epicâ„¢ plus programmer schematic
now picallw is free!
programátor 93c com
bimbla.
dont say that. many guys build 'original' JDM that cannot work because of bugs, bad sys configuration, PIC not in list, poor RS232 and so on
the now free picallw can be a solution with P16pro-like board
pic programming 16f819 velleman
ZeleC said:
Does anyone have the schematics for the pic-mcp-usb found on the olimex site?
here is a schematic that compatible to the PIC-MCP-USB on the olimex site...PIC-MCP-USB is power by USB,but the circuit i attach here need a 16-18V adaptor power supply,so if u want the programmer to work like PIC-MCP-USB, then u need to modify the power supply circuit,use a voltage amplifier chip that can amplifier +5V from USB to 18V 100mA as in PIC-MCP-USB.
icprog k149
hi, manipulator
PIC-MCP-USB is 16f876a based, is it your schematic mplab -> picstart+ compatible and do, you have firmware for the 16f628?
best regards
pony 24c programmer
h**p://www.olimex.com/dev/pic-mcp.html
pic programmer canada
mitesh said:
I want PIC Programmer Schematic, PCB layout, and Programmer Programing software
Hi mitesh,
Are you use PICSTART+,? I have SCH and PCB files of picstartplus,
if you need it , I' ll send it to you.
I'm working it now
regards
MYDIY
epic plus programmer schematics
try this programmer:
http://stor.altervista.org/pic/fcpi...d use very fast software is very good icprog
schema eeprom 93xx et 24cxx
i've been searching whole day for a working PIC-MCP-USB and EPIC PLUS PROGRAMMER Circuit+software. can anyone help me with this? IM VERY NEW TO pic programming. just got my own pic16f84a chip today. desprately need all the help that i can get.
Added after 3 minutes:
pls email me the zipfile if possible. i don have any points to download.
Added after 1 minutes:
shema flash 24c08 pony prog
Hi
Try here: https://www.kitsrus.com
and search for kit K149 (direct link:https://www.kitsrus.com/upuc.html#k149). There u got shematic and software for very good PIC programmer.
This programmer support those PICs:
12C508 16C65A 16C77 16F76 16F877
12C508A 16C65B 16C710 16F77 16F877A
12C509 16C66 16C711 16F737 18F242
12C509A 16C66A 16C712 16F747 18F248
12C671 16C67 16C716 16F767 18F252
12C672 16C620 16C745 16F777 18F258
12CE673 16C620A 16C765 16F83 18F442
12CE674 16C621 16C773 16F84 18F448
12F629 16C621A 16C774 16F84A 18F452
12F675 16C622 16C83 16F87 18F458
16C505 16C622A 16C84 16F88 18F1220
16C554 16C71 16F627 16F818 18F1320
16C558 16C71A 16F627A 16F819 18F2220
16C61 16C72 16F628 16F870 18F2320
16C62 16C72A 16F628A 16F871 18F4220
16C62A 16C73 16F630 16F872 18F4320
16C62B 16C73A 16F648A 16F873
16C63 16C73B 16F676 16F873A Added diypack23:
16C63A 16C74 16F684 16F874 16F5x
16C64 16C74A 16F688 16F874A 10Fxxx 18F6525 6621 8525 8621 (all beta)
16C64A 16C74B 16F73 16F876
16C65 16C76 16F74 16F876A Added diypack25 12F683
By Matjaz
epic plus +pic programer+free download
thanks there. acttually i've been searching for the circuits like more than 10hrs, n im gettin tired. i've been to the kitsrus site but i don quite like the circuits thou. anyway, thanks.it was nice of u. i did get myself the software for microcode as well as the picbasic pro comp.thats y im prefering epic plus programmer. but..as u know. i cant find the circuits. haha. thanks again.
Added after 8 minutes:
Does anyone have the schematics for the EPIC PLUS PROGRAMMER?
micronix+programator
which compiler to use with the programmer?
Added after 18 minutes:
which programmer can i use with this?
pickit serial analyzer not linking
HI
ICprog is good programmer .it works good with several hardware.
the simplest hardware is jdm programmer.
its shematic and icprog and microcodestudio is in the zip file.microcode studio is a basic programmer that need simple commands and convert basic ptograms to hex and C.also i place a simulator for u to enjoy.
if it is usefull help me.
good luck.
