pic microcontroller
Hi, I am a Bangladeshi. Brothers can help me? I am interested in making dead time pwm with mikrocpro for pic. It would be very helpful if someone could help me.
Telling the used a PIC type would be a first step towards useful problem discussion. Also, what's the pwm frequency and dead-time range? Many PIC have feautures for dead-time generation.
Interested in generating 50HZ frequency. With 16f676 or 16f73. And interested in changing duty cycle through adc.
Both are bad choices unless you want to do all of the work yourself. If you do then both have very limited program memory (1K words for the PIC16F676). They are also very old.
Look at something like the PIC18F26K83 which has a CWG module that does what you want.
I'm not sure what you mean by 'changing the duty cycle through ADC' but that MCU has an ADC module as well. It also has a lot more FLASH memory for your code (although the hardware will do pretty much all you want in terms of the critical dead band work).
There may well be other MCUs - this was just the first one I saw that had a suitable PWM configuration.
Susan
LaTeX Commands Quick-Menu:
